 Post subject: does PC-3000 or atola repair/view firmware of this model?
PostPosted: May 5th, 2011, 11:07
My DC can read the model number, the spinning is fine, the heads seems doing the calibration.
my salvation data doctors can't.
 Post subject: Re: does PC-3000 or atola repair/view firmware of this model?
PostPosted: May 5th, 2011, 12:43
First question is: how do you know it's a firmware problem?
PostPosted: May 5th, 2011, 12:46
before to open in a clean room, i prefer to check the firmware modules, and Ram.
what is your suggestion
PostPosted: May 5th, 2011, 13:38
DC is an imaging tool mostly...
PostPosted: May 5th, 2011, 15:05
i agree, i know
as i wrote i have other sd tools but can't read this model of drive, i am asking what do u use for this case.
PostPosted: May 5th, 2011, 17:26
Most people use PC3000, SD, Atola or custom tools.
That will allow to make a proper diagnosis.
PostPosted: May 6th, 2011, 4:15
hi,
fujitsu SD tool support MHZ family here below a picture...
so you can use your tool, you simply need to make the SA MAP file, if you need i can give you teh one i made (PM you email address).
Bye
Luca
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: May 8th, 2011, 6:04
@irs,
This SA map thing can also be implemented in to PC3000 also ?
Users browsing this forum: No registered users and 75 guests
