 Post subject: issues with slow reading of ST3250318AS
PostPosted: May 16th, 2011, 0:11
Hi all
i am having an issue with a seagate 7200.12 as above reading extremely slow. Drive will show correct ID, model and serial numbers, issues are data cant be accessed and during imaging it will image at 1 block a second.
error messages in log are
Starting LBA of RW Request=00000000 Length=FFFFFFFF
ProcessRWError -Read- at LBA 00000000 Sense Code=43110081
Starting LBA of RW Request=00000001 Length=FFFFFFFF
has someone seen this issue before?
furtheromre there are these erros in the modules all other ones are ok
DD power supply switching OFF/ON...
Module 0024........................................................... : Error
Error : Error requesting command state "RD Sys File part" (Drive is not ready)
HDD power supply switching OFF/ON...
Module 0025........................................................... : Error
Module 0026........................................................... : Error
Module 0027........................................................... : Error
Module 0028........................................................... : Error
Error : Drive not ready
Modules reading process completed
thank you
 Post subject: Re: issues with slow reading of ST3250318AS
PostPosted: May 16th, 2011, 3:56
I had a case once similar to it.
Have you seen if the data that is copying is ok or if it's scrambled?
PostPosted: May 16th, 2011, 4:02
Hi
thank you for your reply
So far i am trying to build at least part of an image it has imaged about 1 million blocks only
the imaging process is appearing to be shwing all good green blocks,
what was the issue with your drive ?
PostPosted: May 16th, 2011, 4:03
My drive had a PCB problem.
Swapped PCB+ROM and solved the issue.
PostPosted: May 16th, 2011, 4:07
i tried that but unfortunately the drive behaves the same as the original board
i am the 2nd person who is working on this drive, my issue is that the previous people did a firmware repair/ upgrade, the drive label is a CC38, pc3000 identifies the drive as a CC49, so i am not sure what else may be the case or if this could affect the process somehow.
serial numbers are corect so board must be the original board
