 Post subject: issues with slow reading of ST3250318AS
PostPosted: May 16th, 2011, 0:11
Hi all
i am having an issue with a seagate 7200.12 as above reading extremely slow. Drive will show correct ID, model and serial numbers, issues are data cant be accessed and during imaging it will image at 1 block a second.
error messages in log are
Starting LBA of RW Request=00000000 Length=FFFFFFFF
ProcessRWError -Read- at LBA 00000000 Sense Code=43110081
Starting LBA of RW Request=00000001 Length=FFFFFFFF
has someone seen this issue before?
furtheromre there are these erros in the modules all other ones are ok
DD power supply switching OFF/ON...
Module 0024........................................................... : Error
Error : Error requesting command state "RD Sys File part" (Drive is not ready)
HDD power supply switching OFF/ON...
Module 0025........................................................... : Error
Module 0026........................................................... : Error
Module 0027........................................................... : Error
Module 0028........................................................... : Error
Error : Drive not ready
Modules reading process completed
thank you
 Post subject: Re: issues with slow reading of ST3250318AS
PostPosted: May 16th, 2011, 3:56
I had a case once similar to it.
Have you seen if the data that is copying is ok or if it's scrambled?
PostPosted: May 16th, 2011, 4:02
Hi
thank you for your reply
So far i am trying to build at least part of an image it has imaged about 1 million blocks only
the imaging process is appearing to be shwing all good green blocks,
what was the issue with your drive ?
PostPosted: May 16th, 2011, 4:03
My drive had a PCB problem.
Swapped PCB+ROM and solved the issue.
PostPosted: May 16th, 2011, 4:07
i tried that but unfortunately the drive behaves the same as the original board
i am the 2nd person who is working on this drive, my issue is that the previous people did a firmware repair/ upgrade, the drive label is a CC38, pc3000 identifies the drive as a CC49, so i am not sure what else may be the case or if this could affect the process somehow.
serial numbers are corect so board must be the original board
Users browsing this forum: Bing [Bot], Google [Bot] and 64 guests
