 Post subject: Momentus 5400.6 ticking fast, error on terminal
PostPosted: July 4th, 2011, 9:15
I've a ´Momentus 5400.6 here that is spinning up, then ticking fast a fews times and then quitting with
Rst 0x08M
RW cmd 002F req = 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 00
00 A0 E1
opts = 00000000
RW Err = 84150180
The error is the very same whether the PCB is mated to the HDA or not?!
 Post subject: Re: Momentus 5400.6 ticking fast, error on terminal
PostPosted: July 4th, 2011, 9:24
looks like your drive is dead. was it dropped or subjected to a power outage?
PostPosted: July 4th, 2011, 10:06
Rst 0x08M
00 A0 E1
opts = 00000000
RW Err = 84150180
i guess its the 0 lba, and most probably heads problem
PostPosted: July 5th, 2011, 3:42
I would do proper diag to be extra sure...
PostPosted: July 9th, 2011, 17:55
The solution: water. The net book it came from was soaked, and some of it made its way into the HDA through the head amp/vcm connector.
Probably only an electrical problem that could be solved by replacing the head stack, but as the customer is not willing to pay, we won't never know
