 Post subject: Momentus 5400.6 ticking fast, error on terminal
PostPosted: July 4th, 2011, 9:15
I've a ´Momentus 5400.6 here that is spinning up, then ticking fast a fews times and then quitting with
Rst 0x08M
RW cmd 002F req = 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 00
00 A0 E1
opts = 00000000
RW Err = 84150180
The error is the very same whether the PCB is mated to the HDA or not?!
 Post subject: Re: Momentus 5400.6 ticking fast, error on terminal
PostPosted: July 4th, 2011, 9:24
looks like your drive is dead. was it dropped or subjected to a power outage?
PostPosted: July 4th, 2011, 10:06
Rst 0x08M
00 A0 E1
opts = 00000000
RW Err = 84150180
i guess its the 0 lba, and most probably heads problem
PostPosted: July 5th, 2011, 3:42
I would do proper diag to be extra sure...
PostPosted: July 9th, 2011, 17:55
The solution: water. The net book it came from was soaked, and some of it made its way into the HDA through the head amp/vcm connector.
Probably only an electrical problem that could be solved by replacing the head stack, but as the customer is not willing to pay, we won't never know
Users browsing this forum: No registered users and 226 guests
