 Post subject: WD MyBook Encryption
PostPosted: September 2nd, 2011, 6:06
Been reading other posts on this.
Basically the controller has died (just realized this after drive imaging perfect) and requesting the case
does the initio chip board hold specific info or can you match the model and slot it into another case?
thanks
andy
Databusters Data Recovery Glasgow
http://www.datarecovery.co.uk/latest-data-recovery-jobs/
 Post subject: Re: WD MyBook Encryption
PostPosted: September 2nd, 2011, 6:15
From what I understand you can put the drive into another, identical, case. So if you can get another WDBAAG0010HCH-01 (board number 4061-705059) then you can hook the drive up to that USB-SATA board and it should work.
I've seen a few of these where the problem is just the USB connector that has come loose, have you checked that?
Data Recovery Cape Town
PostPosted: September 2nd, 2011, 6:16
cool, i know the USB on these can control the off/on state. Will give it a wiggle :)
PostPosted: September 2nd, 2011, 6:27
your good :)
PostPosted: September 2nd, 2011, 6:29
Are your soldering skills up to it :wink:
PostPosted: September 2nd, 2011, 6:30
im gonna say no but i will think of something :)
thanks
PostPosted: September 4th, 2011, 2:14
I've got such WD too. But my problem is a little different.
I used My Book for some time. Got some info on it. And then decided to "unfasten" INITIO USB controller and to use the disk via SATA. But Windows7 detected the disk as unallocated. I switched off my PC immediatly and restored the USB-controller. But now I cannot see my info even via USB.
Earlier I saw 2 disks:
1) virtual CD with WD programs and
2) usual HDD with 900+ GB for my data.
Windows showed 2 letters (e.g. E: and F:). Now I see only the virtual CD and no 2-nd letter disk.
How on Earth can I make the USB controller to detect HDD and read my data?
PostPosted: September 5th, 2011, 4:41
drvlas,
Does it was initialized in win7 ?
Angel Data Recovery
PostPosted: September 5th, 2011, 4:45
drvlas,
After connecting it back now ur Data Partition is Gone
use free utility: Partition Find & Mount and you should see it again
give it a shot
PostPosted: September 5th, 2011, 5:56
DR-Kiev wrote:
drvlas,
No, Sir.
I just noticed that smth was wrong and switched my PC off (normal termination of session, of course).
The 1-st 2K of disk is dumped here.
2 einstein9: I've downloaded Partition Find & Mount and started a scan. Slow progress... Wait :)
PostPosted: September 5th, 2011, 6:36
drvlas wrote:
Slow progress...
Well, the progress reached 99% and seemingly stopped.
PostPosted: September 5th, 2011, 6:53
just wait, should work @ the end and u will see ur partition and files
PostPosted: September 5th, 2011, 7:36
If they exist. Well, it stoped and says:
No visible partitions found
No new partitions found
PostPosted: September 5th, 2011, 7:41
if your drive was working and you only removed it from the usb and connect it direct you will not see ur data
by putting it back, u will not see ur partition
by using this freeware it should read ur partition and mount it via USB back again
PostPosted: September 5th, 2011, 7:47
Well, shold I try another methode? I used Intellectual Scan. There're Normal Scan and Thorough Scan. Now I try Thorough Scan
PostPosted: September 6th, 2011, 1:39
It runs for 18 hours by now.
After 6 or 7 hours from start it reached 99 % and no visible changes from that time. Should I break the scan? As far as I know, there is only 1 partition on the disk. And 1 partition is detected.
And, break scan or not, what is the next step? For dummy, pls!
PostPosted: September 6th, 2011, 3:06
Man, 18h is very long time to wait
could you try to open it with winhex and post the header image of it here
PostPosted: September 6th, 2011, 3:29
So I can break it?
Before the Partition Find & Mount program I've launched DDME one. Here is a dump. Isn't it the info you ask?
PostPosted: September 6th, 2011, 3:40
Its likely there is something wrong so I would stop the scan and check any results.
Then I would then check the smart attributes.
Then I would very likely check the drive in Dmde to see what partition info is available.
PostPosted: September 6th, 2011, 4:03
Well, I stopped the scan. Here are the properties of partition found.
The choice is not too rich:
- to create the image file
- to mount partition
Please tell me is the dump (my previous post) shows that partition info?
Users browsing this forum: No registered users and 82 guests
