 Post subject: ST31000528AS ready after 20 sec.
PostPosted: October 16th, 2011, 9:30
i have got this 7200.12 ST31000528AS FW CC34.
the drive spin, make some high noise for 2 seconds like difficulty in calibration, than stay quite continuing spinning. it reach ready state and ID only after 20 seconds.
Drive was not dropped.
i can read all SA and i made backup, but i can't read sectors becouse it goes in timeout.
I am considering to regenerate traslator.
 Post subject: Re: ST31000528AS ready after 20 sec.
PostPosted: October 16th, 2011, 9:32
try to clear the smart and post the terminal log for better proper diagnose
post the terminal log from the beginning before n after the smart clearing
might be heads not sure
PostPosted: October 16th, 2011, 9:37
Test : Reset S.M.A.R.T
SMART erase...
Reset S.M.A.R.T................................... : Error
Drive not ready
Rst 0x20M
(P) SATA Reset
PASS
RW: Error processing Performance Parameter File: 203C
Send Status: COMRESET seen
InitiateMarkPendingReallocateRequest for disc_lba: 00000067
PostPosted: October 16th, 2011, 9:53
i mean the moment you power ur drive ON till the end
post the log
PostPosted: October 16th, 2011, 14:26
post the log
From power ON:
Rst 0x20M
(P) SATA Reset
PASS
till the END (drives gets ready)
why it was not good my previous post?
( if i try to reset smart,the drive goes to timeout and stay busy)
PostPosted: October 16th, 2011, 14:33
Pending bug? I've only seen that on Nighthawk though.
Data Recovery Cape Town
PostPosted: October 16th, 2011, 15:04
PESSIMA idea e col cavolo che funziona in queste condizioni.
REALLY BAD IDEA and it won't work even if you cry.
PostPosted: October 17th, 2011, 1:53
did u try to clear the G?
PostPosted: October 17th, 2011, 2:35
Common in 7200.12. This specific problem can be solved under 'HDD ID EDITING' commands within PC3K utility
Users browsing this forum: Google [Bot] and 105 guests
