 Post subject: If the ROM is damanged, then what are my options?
PostPosted: November 22nd, 2011, 9:32
The person who attempted to do the ROM swap busted a pin off my ROM chip.
So what are my options? Would an exact match PCB work? Am I stuck sending it in to a data recovery service?
 Post subject: Re: If the ROM is damanged, then what are my options?
PostPosted: November 22nd, 2011, 9:40
Another great first post..........
No Hi.
No drive make or model.
No explanation as why the rom had to be swapped in the first place.
Data recovery dosn't include use of a crystal ball. :lol:
PostPosted: November 22nd, 2011, 9:49
Apparently you didn't get the memo . . .
http://www.datasaversllc.com
PostPosted: November 22nd, 2011, 9:51
No Hi.
First Hi :D
you've not used Mystic Megs service then :lol:
PostPosted: November 22nd, 2011, 10:48
I use a Black Ball, when more powerful analysis needed sometimes TWO... does it count ? :mrgreen:
So said, ask the person who busted the pin to remedy, if possible, at first. A broken pin is not the end of the world if you have the right tools and 10 minutes.... as a definitive rework is most probably NOT necessary.
Depending on the drive / model / brand it is more / much more / less difficult to get data even when original ROM/FLASH is totally lost. But it takes someone who knows his stuff ;)
PostPosted: November 22nd, 2011, 16:35
just hope it's not a 7200.11,12 seagate.
PostPosted: November 22nd, 2011, 16:57
As mentioned above the best solution would be to fix the problem of the missing pin on the ROM IC - shouldn't be too big a deal for someone who knows what they're doing.
Data Recovery Cape Town
PostPosted: November 24th, 2011, 8:05
WD drives due there engineering design have multiple SA copies on platters ,so even if original pcb is lost ROM can be regenerated.
In case of seagate recovery will be next to impossible.
Users browsing this forum: Google [Bot] and 96 guests
