 Post subject: WD Hulk Healthy SA - but no access to surface
PostPosted: December 13th, 2011, 17:20
after a headswap i can edit in ram head map and disable H3,H5 and get drive ID correctly.
but after building a map in DE i have got all blacks sectors.
seems like nly in Hulk family there is this issue reading prevoious post.
If somebody has solved and want to point me, just PM me. :mrgreen:
 Post subject: Re: WD Hulk Healthy SA - but no access to surface
PostPosted: December 14th, 2011, 9:22
Check the ACE forum.
Data Recovery Cape Town
PostPosted: December 14th, 2011, 9:37
When you edit head map in RAM what do you change map to? Maybe there is problem with the 'paired' head you use in map to substitute for bad head.
PostPosted: December 14th, 2011, 9:56
0.1.2.2.4.4.6.7
PostPosted: December 14th, 2011, 10:12
positivebit wrote:
0.1.2.2.4.4.6.7
Try 0.0.0.0.0.0.0.0 before soft reset, then set back to 0,1,2,3,4,5,6,7 (or what map you need)
PostPosted: December 14th, 2011, 17:33
hddguy wrote:
positivebit wrote:
0.1.2.2.4.4.6.7
That's what I usually do.
Users browsing this forum: Google [Bot] and 148 guests
