 Post subject: Dirty Data Recovery Job for someone.
PostPosted: January 14th, 2012, 8:52
All right first I'll be honest and you be nice, or at least try.
I am a complete noob, and I have committed every HDD sin.
I had a WD 500gb Cavair Green drive that failed and I needed data now.
Backups?
This drive was in a MS Small Business Server environment.
My tech who set it up had set the backup to the an old Quickbooks file.
What I did-
I took the cover off here in my office, peeped in, and saw that the head was hanging down from the top arm.
I found a WD 500gb Cavair Black that "looked" the same, set up a "filtered" air supply, got me some gloves and poked holes in a clear garbage bag, and smugly proceeded to put the platter from the Green drive into the Black drive.
Also replaced the circuit board from the Green drive into the Black drive.
No go.
Surprise.
Now I am asking you guys what to do, who to offer the job of cleaning the disk and recovering the 1 Quickbooks file I need so badly.
My sanity is at stake.
 Post subject: Re: Dirty Data Recovery Job for someone.
PostPosted: January 14th, 2012, 10:36
Let me get this straight: how many platters were in the Green drive? If just one, then this deal is still possible. If more than one, begin re-keying your Quickbooks data. No need to criticize your technique here; I think you realize how badly you screwed this up. At any rate, answer the first question and we'll see where to go from there.
PostPosted: January 14th, 2012, 10:53
I'm sorry that this isn't a directly helpful question, but I'm curious . . . what prompted you to try it yourself? A YouTube video?
http://www.datasaversllc.com
PostPosted: January 14th, 2012, 14:04
msurgeon- There is only one platter.
jono-ats- youtube did not make me do this. I only went there afterwards.
My naivety and DIY genes are to blame.
PostPosted: January 14th, 2012, 16:22
This could still be possible, IMHO. You understand this will cost you x-times more than what it'd cost if you sent it to a pro at the very beginning, right?
If you didn't damage platter, then it could need it cleaned and heads installed.
This is a fairly tough one.
I suggest you send your stuff to Jono-ats. If someone can do this, that's him.
PostPosted: January 14th, 2012, 17:09
Thanks, Northwind, for you vote of confidence.
We won't charge you more (we have flat rates), but there is a $100 charge for opened drives regardless of outcome.
PostPosted: January 14th, 2012, 17:59
jono-ats, - Please call me [phone number removed as no longer relevant to the thread]
PostPosted: January 14th, 2012, 18:25
Hey I kind of understand the diy genes bit but why did you choose to swap the platter when it was the damaged headstack which obviously required swapping out? Most likely the platter now has media damage of some kind.
Good luck anyway!
PostPosted: January 14th, 2012, 18:29
dick- I thought I have to remove the platter to get the heads out.
Why then not just let the heads there and ease the platter out and into a new home?
(reminder- I'm honest and you're nice)
PostPosted: January 15th, 2012, 7:27
I also suggest sending to jon.
PostPosted: January 20th, 2012, 8:03
Drive arrived at Jon's facility.
Will keep you posted on results.
PostPosted: January 20th, 2012, 13:16
Go Jon Go! :)
PostPosted: January 20th, 2012, 16:10
northwind wrote:
Go Jon Go! :)
Nothing like a bit of spotlight pressure!!!
PostPosted: January 26th, 2012, 1:32
It like American Idol go jono go
Your fan
PostPosted: February 1st, 2012, 15:40
I've got the drive restored to working condition and the resources backed up. We're in the process of copying data from the drive (slowly). However, the game ain't over 'till it's over . . .
Jono
PostPosted: February 2nd, 2012, 3:17
:good: :)
PostPosted: February 2nd, 2012, 4:05
Nice one! :-)
PostPosted: February 2nd, 2012, 4:14
Kudos :)
Data Recovery Cape Town
PostPosted: February 2nd, 2012, 11:33
AMAZING!!!
PostPosted: February 2nd, 2012, 11:56
Assuming jono pulls it off, this thread needs to be a sticky in the DIY thread.
Users browsing this forum: Cleanroom, Google [Bot] and 135 guests
