 Post subject: WD20EARS With a mild attitude problem.
PostPosted: March 15th, 2012, 14:36
Drive came in, clicking. ( Unsure if its been dropped ) - Probably has
anyway , head swap went well and 0,1,2,3,4 are just fine.
I can't read anything from H5, nothing, zip , nada.
Micros are fine , Head map , and donor are good.
any ideas chaps? , not tried these heads back in donor, getting what I can just in case.
merci
andy
Databusters Data Recovery Glasgow
http://www.datarecovery.co.uk/latest-data-recovery-jobs/
 Post subject: Re: WD20EARS With a mild attitude problem.
PostPosted: March 15th, 2012, 15:30
happens from time to time. On some swaps i can get only certain heads to read so i image em and do another swap to image the rest. Apparently it was a SOP with Zeus drives =) ( had a few successes with them using up to 4 donors on a single drive )
PostPosted: March 15th, 2012, 15:34
very helpful thanks
PostPosted: March 15th, 2012, 16:22
Sounds like you'll have to pull another stunt like that one you did for the singer dude :)
Data Recovery Cape Town
PostPosted: May 12th, 2012, 15:17
merci
andy
Hello buster80, I am having problems with the same WD20EARS 2TB harddrive, see my topic at: not-recognized-harddrive-t22923.html . My harddrive is not being recognized. Do you think swapping the head will help in my situation? Or do you think i should first replace the pcb, to see if this works?
Do you know a good tutorial which will help me with my situation?
Users browsing this forum: Doomer and 54 guests
