 Post subject: I'm searching for this PCB Hitachi 750 giga P/N 0A38115
PostPosted: March 21st, 2012, 16:54
Hitachi 750 giga
P/N 0A38115
Model HDT7201075SLA360
MLC: BA3013
Made in China Nov 2008
Looking for the PCB described above
 Post subject: Re: I'm searching for this PCB Hitachi 750 giga P/N 0A38115
PostPosted: March 21st, 2012, 18:04
Post on the HARD DRIVE MARKET section not here.
PostPosted: March 21st, 2012, 20:25
Ok but I'm also interested by tips or advices to fix short on the PCB.
PostPosted: March 21st, 2012, 21:59
Then have to describe what you think let to the failure, the drive's current behavior, post some pictures of the PCB, etc.
PostPosted: March 22nd, 2012, 5:49
I tested the TVS diode near the power in, I detect a short when I test with an ohm meter on de PCB out of hdd. There is not other sign like burned part. This evening I'll try tu send a picture.
Thanks for your interest.
PostPosted: March 24th, 2012, 20:30
Remove the shorted diode. If there is no other problem with the PCB, then you won't need to visit the Hard Drive Market.
Good luck.
PostPosted: March 26th, 2012, 9:19
Good luck.
Many thanks for this advice, Fzabkar, I removed the diode and I could backup all the disk.
Here is the picture of the PCB, the diode is circled in red, so can help another guy.
PostPosted: March 27th, 2012, 1:36
I would have thought that the "L14" component was the 12V TVS diode. :?
PostPosted: March 27th, 2012, 5:41
File comment: This is the correct picture with the L14 tvs diode I removed
Oh sorry, you're right :oops: I removed the "L14" as you tell but I did a mistake when I circled in the picture.
So, the L14 I removed is at the right of the circled one, and is 12V.
Users browsing this forum: Google [Bot] and 59 guests
