 Post subject: Who can repair my WD5000AAVS?
PostPosted: April 2nd, 2009, 23:04
I have
Model WD5000AAVS - 00ZTB0
DCM HBNNNT2CHB
I plug it in, it sounds like it spins up, but I get nothing. Every so often it just spins down by itself. No strange clicking noises or anything like that. When its spinning everything sounds great, and I can hear it doing some reads or something like that when first turned on.
I have a donor drive which is the following:
Model WD5000AAKB - 00YSA0
DCM HBRNHT2CBB
I am not sure if it can be used, but I am just saying I have this other drive.
How much will someone reputable charge me to fix this? Who is reputable? If my donor is good, then obviously they can have that, but if it isn't I would be wanting to know all inclusive as I don't feel like going drive hunting, would rather just someone fix.
Brian
 Post subject: Re: Who can repair my WD5000AAVS?
PostPosted: April 2nd, 2009, 23:57
I don't think these two can interchange... May be I'm wrong... It's just my educated guess
PostPosted: April 3rd, 2009, 0:20
jono-ats is the closest one to you and very reputable member.
He will be able to help you.
There is also others on this forum, who will be able to help.
Just take your time reading this forum and you will find the one that you wish to go with.
www.datarecoveryne.com
PostPosted: April 3rd, 2009, 1:24
Jono-ats is the closest to your location and yes he can get your data!!!!
PostPosted: April 3rd, 2009, 3:00
Yes, agree. Recommend jono-ats.
Good luck
PostPosted: April 3rd, 2009, 6:55
Thank you for your votes of confidence.
I'll P.M. the fellow with contact info.
Best regards,
Jono
http://www.datasaversllc.com
PostPosted: April 3rd, 2009, 9:08
I also recommend jono-ats for this DR case. He's reputable and has vast experience to deal with WD drives.
Just one question to the OP, about your drive, is it from WD MyBook ?, or is it just bare drive ? I have seen many AAVS from MyBook recently sent in to my DR workshop, all giving same problem like you described.
I suspect something is really wrong with the design of WD MyBook if this is the case.....or everything is wrong with WD ? :D
My Forum
PostPosted: April 3rd, 2009, 9:27
Yes its from a mybook.
I hoped the mybook case was the problem, so I extracted the drive, and plugged it in using a USB->SATA cable and still no dice.
What seemed to be the problem with these mybook drives you worked on? I am sure its the same issue with this one.
PostPosted: April 3rd, 2009, 10:05
We see a fair number of My Book drives. I think most of them have PCB problems, although some have bad heads. Corrosion seems to be a big factor . . . maybe the rubber pad has some reactive ions that make friends with the solder on the PCB.
Jono
PostPosted: April 3rd, 2009, 11:01
Jono has the experience i recomend too
PostPosted: April 3rd, 2009, 11:31
GO JONO!!
PostPosted: April 3rd, 2009, 18:38
Yeah, I've started to get a bunch of these AAVS drives in from MyBooks as well. A refreshing difference from what used to be in them (WD5000KS).
PostPosted: April 6th, 2009, 17:17
It is becoming increasingly hard to detect the real issue of these 500GB Western Digital. The chance to find a compatible donor is very low--To perform data recovery on these hard drives require extensive knowledge in firmware and head transplant--it is one of these horses we have to tame--
The last word from the dying patient, data.
www.datamediarecovery.com
PostPosted: December 8th, 2009, 16:15
Hi!
I have the same problem as described here. Can i do my self something to restore data? Is this disk now totally useless?
Disk is from MyBook World Edition.
Who fixing that kind of problems?
Where is the nearest place?
Hom much it will costs?
PostPosted: December 8th, 2009, 16:22
a few guys on here from the UK and a few from hungary, depends on where you want to send it and how much you are willing to spend
PostPosted: December 8th, 2009, 16:43
i don't want spend much, but if the price is reasonable, then i want to restore all of my pictures, software and music backups. I think it will cost me too much... 25€ send to UK, 100€ for new disk, 25€ to send data to me back + data restoration ?? €
PostPosted: December 8th, 2009, 17:27
Send it to Russia - it will be cheaper
or you can find local guys in Tallinn
PostPosted: December 8th, 2009, 20:20
true.
If not, we can do it in hungary.
PostPosted: December 9th, 2009, 3:59
Send it to Greece Xronis can repair it for you no problem
Iorana Haraharaini
PostPosted: June 11th, 2010, 21:41
A friend of mine gave me a WD5000AAVS making a click-click noise (but spinning normally) once powered up. She dropped it (was an external) while actually accessing it! :S
As I didnt manage to detect it even as hardware, I removed the cover to see that the 2 out of 4 heads were dead. One was actually broken and bent towards its pair head and then stuck together in the parking guide.
I have another WD5000AAVS. Can I swap the whole head unit?
Users browsing this forum: Google [Bot] and 67 guests
