Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: ST2000DM001 BSY
PostPosted: July 9th, 2012, 5:24
Model: ST2000DM001
FW: CC4C
Drive stays busy and writes to terminal:
Boot 0x40M
Spin Up
TCC-001B[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-001B
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MCMainPOR: EXCEPTION: MCMT PRI copy corrupt
MCMainPOR:  MCMT SEC copy valid
Reconstruction: MCMT Reconstruction Start
  Max number of MC segments 0A61
Nonvolatile MCMT sequence number 0008281B
[RSRS] 04E0
ProcessRWError -Read-   at LBA 000000000003F171  Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000003F171!
Reconstruction: EXCEPTION: Seg Read Fail: Status = 0000
Continuing after error
Reconstruction: Completed 1:
[MCMTWS]
Rst 0x40M
Spin Up
TCC-001B
LED:00000047 FAddr:FFFFFFFE
Heads are fine, worked on another drive. Donor heads does not work on patient, gives same output from terminal as original heads.
After changing back original heads I can hear two louder head positioning sound and in terminal I get this:
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
TCC-001A[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
Spin Up
TCC-001A
RECOV Servo Op=0900 Resp=0005
(P) SATA Reset
MCMainPOR: Start:
[RSRS] 04E0
[MCMTWS]
Rst 0x40M
Spin Up
TCC-001A
So maybe someone gives me hint whats wrong with this drive? Is this "BSY problem" as seen on 7200.11 series?
 Post subject: Re: ST2000DM001 BSY
PostPosted: July 9th, 2012, 8:38
No, definitely not the "BSY problem" as per .11 series.
Looks to me like some bad areas in SA.
Data Recovery Cape Town
PostPosted: July 9th, 2012, 15:54
Agree
You are an imperfect hard drive...Finding your weakness is only a matter of time
PostPosted: July 9th, 2012, 18:17
Did you try to off PendingReallocateRequest ?
PostPosted: July 10th, 2012, 10:55
What do you mean?
PostPosted: July 10th, 2012, 18:29
I mean have you tried to set a "BGMSFlags" in the disable ?
PostPosted: July 19th, 2012, 8:02
No, I can't do nothing because it stays busy. Also can't access terminal, anyone knows shorting points for this pcb 100664987 REV A?
PostPosted: March 3rd, 2013, 17:01
@pekka
Did you ever solve your problem?
I have the same hard disk you have and with the same problem.
When I open the Hyperterminal and press CTRL+Z, the only message I get is a continuously repeat:
and so on.
I can't even put any command!
Thank in advance.
PostPosted: March 3rd, 2013, 17:06
aliasofiuco wrote:
@pekka
and so on.
Thank in advance.
No.
Have you tried shorting reading channel to get access to terminal?
PostPosted: March 3rd, 2013, 17:11
No. I'm totally newbie in dealing with Hard Disks.
I don't even know what are you talking about.
Are you suggesting me to use a jumper to join the pins GND TX RX?
PostPosted: December 22nd, 2013, 11:34
Has anybody found a way to solve this problem yet?
I have a similar problem with this drive. I have the terminal connection but get a ProcessRWError
and the drive keeps outputting text to the terminal. I can't type anything. Also can' t find any useful information on the code "0xC3160081" that it generates.
Starting LBA of RW Request=000000000E96E947  Length=00000004
ProcessRWError -Write-  at LBA 000000000E96E947  Sense Code=C3160081
[000000001D322661]vvvvvvvvvv[000000001D322662]vvvvvvvvvv[000000001D322663]vvvvvvvvvv[000000001D322664]vvvvvvvvvv[000000001D322665]vvvvvvvvvv[000000001D322666]vvvvvvvvvv[000        000001D322667]vvvvvvvvvv[000000001D322668]vvvvvvvvvv[000000001D322669]vvvvvvvvvv        [000000001D32266A]vvvvvvvvvv[000000001D32266B]vvvvvvvvvv[000000001D32266C]vvvvvv        vvvv[000000001D32266D]vvvvvvvvvv[000000001D32266E]vvvvvvvvvv[000000001D32266F]vv        vvvvvvvv[000000001D322670]vvvvvvvvvv[000000001D322671]vvvvvvvvvv[000000001D32267        2]vvvvvvvvvv[000000001D322673]vvvvvvvvvv[000000001D322674]vvvvvvvvvv[000000001D3        22675]vvvvvvvvvv[000000001D322676]vvvvvvvvvv[000000001D322677]vvvvvvv
After a bit a does a request for file save:
[000000001D3226DF]vvvvvvvvvv
(DOS) Requesting File Save
[000000001D3226E0]vvvvvvvvvv[000000001D3226E1]
PostPosted: December 22nd, 2013, 14:29
doncgambino:
There is SRS (Seagate Recovery Services) facility in Amsterdam, they can recover data for you.
Sorry but it is usually not so simple as "LED CC fix"...
PostPosted: December 22nd, 2013, 20:11
It's a firmware corruption issue.
http://www.datasaversllc.com
PostPosted: May 18th, 2014, 4:33
Has anybody found a solution to solve this problem :?:
@jono-ats
hi
do you have any solution for this problem?
thanks
PostPosted: May 19th, 2014, 10:34
You might try clearing SMART and rebuilding the translator, after taking the appropriate precautions.
PostPosted: May 14th, 2016, 4:06
I'll get this necro-topic to life. May be it would be helpfull for someone.
I had a problem with seagate barracuda green 2tb st2000dl003
This helped me:
F3 A>R0,10000
F3 A>R10000,10000
F3 A>R20000,10000
F3 A>R30000,10000
F3 A>R40000,10000
F3 A>R50000,10000
F3 A>R60000,10000
F3 A>R70000,10000
F3 A>R80000,85a1
F3 2>P0000,0000
F3 A>W0,10000
F3 A>W10000,10000
F3 A>W20000,10000
F3 A>W30000,10000
F3 A>W40000,10000
F3 A>W50000,10000
F3 A>W60000,10000
F3 A>W70000,10000
F3 A>W80000,85a1
detach power, wait for 10 sec and attach it back
HDD will recover media cache. After this you can shutdown your pc and connect hdd to sata and power.
Found this here:
http://forum.ru-board.com/topic.cgi?for ... tart=20#16
http://forum.ru-board.com/topic.cgi?for ... art=100#10
Hope this can help someone as it did for me. GL!
PostPosted: May 15th, 2016, 8:40
Sorry, i cant edit previous msg and post PMs.
labtech asked me about drive's behavior in the terminal upon power on BEFORE issuing these commands.
Sorry, but i didnt save those logs. I dont do hdd recovery professionally, it was my own hdd. It showed up in bios (once per reboot) and didnt show in OS, or programs like victoria or mhdd.
But i had the same output as doncgambino
OFC those numbers were different.
By googling "ProcessRWError -Write-" i got to this forum. People here said its hard to fix it yourself, but it is not.
PostPosted: May 16th, 2016, 10:41
Thx for reply
PostPosted: May 17th, 2016, 17:12
Thank you xeonium!!!
PostPosted: October 27th, 2016, 16:59
i will try method of xeonium..
try red pins first, and if they not work, try yellow pair.
from entec
Users browsing this forum: Google [Bot] and 89 guests
