 Post subject: Barracuda 7200.7 ST3160828AS in busy state - help
PostPosted: August 8th, 2012, 15:53
Hello, i've this Barracuda 7200.7 ST3160828AS with firmware 3.04 in busy state.
No head clicking and motor spins good.
Hyper terminal detects it in T level but i don't want to do anything more until i know the right procedure.
SeDiv detects the drive with correct S/N
I don't think the fix procedure is the same of 7200.11 serie, so i hope you can help me with the right procedure to fix it.
Thank you.
My firmware database:
 Post subject: Re: Barracuda 7200.7 ST3160828AS in busy state - help
PostPosted: August 8th, 2012, 16:14
Hi, nothing in terminal?
PostPosted: August 8th, 2012, 17:06
Terminal detects the drive, i'm only afraid to do mistake with comands.
Which are the comands in terminal for busy fix with barracuda 7200.7 ??
PostPosted: August 8th, 2012, 17:16
He means what comes up in terminal when you apply power.
I.e. any error messages.
There is no magic commands for "busy fix" on 7200.7 :-(
PostPosted: August 8th, 2012, 17:20
This:
T>Interface task reset
4096k x 16 buffer detected
PUMA2 - 1_Disk    0.03  12-12-05 14:40
              Spin Ready
3.04  12-12-05 14:42  4096k x 16 buffer
(P)(H)SATA Reset
Restore
PostPosted: August 9th, 2012, 2:36
SeDiv the same of terminal when i apply power, but it shows me also the serial number of the drive:
PostPosted: August 9th, 2012, 9:31
Is it possible to fix with terminal?
I also downloaded "Seagate Firmware Repair 5.0" from Salvation Data (to install it i had to install my old Win 98 SE) :lol: :
http://www.salvationdata.com/data-recov ... rapair.htm
The demo version is able to fix only Barracudas 7200.7 (i'm lucky) but unfurtunally gives me "Err TYPE".
To solve this problem i followed the PDF manual which says to switch off power supply to the drive, then switch it on, press [CTRL+C] and perform [Power Reload], but always keep saying "Drive not detected" and if i push [Reload] button keeps saying "Err TYPE".
Hope you can help me :wink:
PostPosted: August 9th, 2012, 11:38
Any idea? :roll:
PostPosted: August 10th, 2012, 3:36
So, what does it mean this terminal log?
Can i fix it?
              Spin Ready
(P)(H)SATA Reset
Restore
PostPosted: August 10th, 2012, 6:11
Consiglio amichevole : se continui a voler fare le cose con QUESTI strumenti in questo modo e' molto difficile ottenere sia risultati sia soprattutto AIUTO specialmente QUI dai professionisti. Non posso dirti altro.
Friendly advice : if you keep going on with THESE tools / stuff THAT way it is very difficult to obtain RESULTS and HELP , especially HERE from the pros. Enough said.
PostPosted: August 10th, 2012, 6:17
Perfavore dimmi tu come dovrei risolvere il problema, e quale può essere il problema. Grazie.
Please, tell me how should i fix this hard drive, and what could be the issue. Thanks
PostPosted: August 11th, 2012, 4:22
This is a factory logos made with SeDiv, hope you gurus can analyze this:
Show Factory Logs.zip [236.9 KiB]
Downloaded 760 times
PostPosted: August 12th, 2012, 10:40
This is a new terminal log, hope will help you gurus to find where's the problem.
              Spin Ready
(P)(H)SATA Reset
Restore
T>AT Stuff
0000: 0c5a  3fff  c837  0010   0000  0000  003f  0000
0008: 0000  0000  2020  2020   2020  2020  2020  2020
0010: 344d  5432  5134  325a   0000  4000  0004  332e
0018: 3034  2020  2020  5354   3331  3630  3832  3841
0020: 5320  2020  2020  2020   2020  2020  2020  2020
0028: 2020  2034  3059  3930   3436  4c45  4e20  8010
0030: 0000  2f00  4000  0200   0200  0007  3fff  0010
0038: 003f  0000  0000  0010   ffff  0fff  0000  0007
0040: 0003  0078  0078  00f0   0078  0000  0000  0000
0048: 0000  0000  0000  001f   0506  0000  0040  0040
0050: 007e  001b  346b  7d01   4003  0061  3c00  4003
0058: 007f  0000  0000  fefe   fffe  0000  fe00  0000
0060: 0000  0000  0000  0000   9eb0  12a1  0000  0000
0068: 0000  0000  0000  0000   0000  0000  0000  0000
0070: 0000  0000  0000  0000   0000  0040  0f42  0000
0078: 0000  0000  0140  0000   0000  0000  0800  0180
0080: 0001  9eb0  12a1  9eb0   12a1  2020  0002  42b6
0088: 8002  008a  3c06  3c03   0000  07c6  0100  0800
0090: 1708  1200  0002  0080   0000  0000  0020  0002
0098: 0000  fe03  0000  0000   0000  0000  00cb  000b
00a0: 000f  0006  0003  0000   0032  0014  0033  0024
00a8: 000f  001e  0032  0000   0013  0061  0032  0014
00b0: 0022  0000  001a  0000   0012  0000  0010  0000
00b8: 003e  0000  0000  0000   0032  0000  0000  0000
00c0: 0000  0000  0000  0000   0000  0000  0000  0000
00c8: 0000  0000  0000  0000   0000  0000  0000  0000
00d0: 0000  0000  0000  0000   0000  0000  0000  0000
00d8: 0000  0000  0000  0000   0001  0000  ffff  ffff
00e0: 0000  0000  0000  0000   0000  0000  0000  0000
00e8: 0000  0000  0000  ffff   00bd  0000  0000  0096
00f0: 0001  0000  0000  8100   0004  0000  0000  0000
00f8: 0000  0000  0000  15e0   0000  0000  0000  0000
Configured-1
Part #: 100383426
PUMA2 - 2_Disk    3.04  12-12-05 14:42  4096k x 16 buffer
Built for PUMA2,PITKIN,Redback,TI1761 PreAmp,InternalSpin,GC110,SVC127,OneToOne,
2Disk,LowDelta,220 Servos,7200RPM,8Pole,NonModGray,100MHz,Code DRAM,Early Exit,S
tall Converter,RwFeat=0000,SeaDex,VBPI,MDW
Eng Rev = .022
CERT Rev = NONE
Mask Rom Rev = 0.03
( VALID Cert Disk Code Detected - Revision # .006
T>Pgm=00 Trk=FFFFF(0EC74[0F6CE]).1(1).134(FFF) Zn=0 Err=00 ErCt=0000 Hlth=0008 C
Hlth=0000 Ready LBA=079C985B
Age=50 Type=CB MxCyl=164F7 MxHd=3 MxSct=44C BSz=2000 TCode=00000000
:50000008CB000003  AX`4MT2Q42Z'  "000000000000"0EC2D-0ECB4
SRAM Ovly = Diag
RL:0200
AL:0203
SL:021A
RD:0400:0010
WR:0410:0010
FM:0420:0007
AD:0420:000B
BA:0427:0003
ST:042A:0001
AC:042B:01FF
DP:042B:01FF
AS:062A:007F
SC:06A9:0201
logbps :0200
codebps:0200
uP:3FE0
MZ:3FE0
T>k
Head Mask = FF
Map 00 to 00 00
Map 01 to 01 01
Map 02 to 02 02
Map 03 to 03 03
T>y
                                  PhysCyl   GrayCyl
First System Cylinder            0000EC2D  0000F68E
First Zero Offset Cylinder       0000EC37  0000F698
First App Code Cylinder          0000EC42  0000F6A3
Second App Code Cylinder         0000EC43  0000F6A4
Second Zero Offset Cylinder      0000EC4E  0000F6AF
Third App Code Cylinder          0000EC59  0000F6BA
Fourth App Code Cylinder         0000EC5A  0000F6BB
First Adaptives Cylinder         0000EC5B  0000F6BC
First User Defect List Cylinder  0000EC5C  0000F6BD
First Alternate Pool Cylinder    0000EC60  0000F6C1
Second User Defect List Cylinder 0000EC70  0000F6D1
First Cert Code Cylinder         0000EC74  0000F6D5
First Intf Code Cylinder         0000EC76  0000F6D7
First Intf System Cylinder       0000EC78  0000F6D9
First SEADEX Cylinder            0000EC7E  0000F6DF
First Cert Log Cylinder          0000EC90  0000F6F1
First Decay Cylinder             0000ECA7  0000F708
First SPLASH Cylinder            0000ECB4  0000F715
Last System Cylinder             0000ECB4  0000F715
T>/2
2>x
Head 00
Zone 00:  00018 - 0132D  1100 (044C) 687.097
Zone 01:  0132E - 03BFE  1045 (0415) 663.594
Zone 02:  03BFF - 05D87  1012 (03F4) 644.516
Zone 03:  05D88 - 07831   990 (03DE) 627.097
Zone 04:  07832 - 09073   953 (03B9) 606.774
Zone 05:  09074 - 0A797   916 (0394) 585.484
Zone 06:  0A798 - 0C72C   880 (0370) 551.613
Zone 07:  0C72D - 0D653   836 (0344) 535.777
Zone 08:  0D654 - 0E8AC   806 (0326) 515.881
Zone 09:  0E8AD - 0FD7A   770 (0302) 491.129
Zone 0A:  0FD7B - 10DD3   733 (02DD) 471.216
Zone 0B:  10DD4 - 1204F   691 (02B3) 448.680
Zone 0C:  12050 - 137F9   660 (0294) 417.339
Zone 0D:  137FA - 145B5   616 (0268) 401.985
Zone 0E:  145B6 - 155F4   586 (024A) 381.567
Zone 0F:  155F5 - 164F7   550 (0226) 357.097
Head 01
Head 02
Head 03
Reserve:  0EC2D - 0ECB4   640 (0280) 454.147
Total KBAs = 12AF3C2B
2>/0
T>D4E
Cert Table loaded
og 4E - Health 0008 - HlthDtl 000F - Cert Rev = .006 - Rom Rev = 3.04.022 - Time
= 00:00:09 Log Type = 01
Log 02 - Health 0000 - HlthDtl 0000 - Time = 01:13:15 Log Type = 01
Log 82 - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 01
Log 83 - Health 0000 - HlthDtl 0000 - Time = 00:08:19 Log Type = 01
Log 84 - Health 0000 - HlthDtl 0000 - Time = 00:00:54 Log Type = 01
Log 03 - Health 0000 - HlthDtl 0000 - Time = 00:29:38 Log Type = 01
Log 73 - Health 0000 - HlthDtl 0000 - Time = 00:00:44 Log Type = 01
Log 05 - Health 0000 - HlthDtl 0000 - Time = 00:00:10 Log Type = 01
Log 06 - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 01
Log 07 - Health 0000 - HlthDtl 0000 - Time = 00:00:33 Log Type = 01
Log 0F - Health 0000 - HlthDtl 0000 - Time = 00:34:34 Log Type = 01
Log 10 - Health 0000 - HlthDtl 0000 - Time = 00:18:40 Log Type = 01
Log 11 - Health 0000 - HlthDtl 0000 - Time = 00:18:38 Log Type = 01
Log 12 - Health 0000 - HlthDtl 0000 - Time = 00:11:15 Log Type = 01
Log 13 - Health 0000 - HlthDtl 0000 - Time = 00:11:16 Log Type = 01
Log 14 - Health 0000 - HlthDtl 0000 - Time = 00:11:16 Log Type = 01
Log 15 - Health 0000 - HlthDtl 0000 - Time = 00:10:51 Log Type = 01
Log 16 - Health 0000 - HlthDtl 0000 - Time = 00:10:20 Log Type = 01
Log 17 - Health 0000 - HlthDtl 0000 - Time = 00:10:50 Log Type = 01
Log 18 - Health 0000 - HlthDtl 0000 - Time = 00:03:52 Log Type = 01
Log 19 - Health 0000 - HlthDtl 0000 - Time = 00:18:10 Log Type = 01
Log 1A - Health 0000 - HlthDtl 0000 - Time = 00:11:18 Log Type = 01
Log 1B - Health 0000 - HlthDtl 0000 - Time = 00:11:11 Log Type = 01
Log 1C - Health 0000 - HlthDtl 0000 - Time = 00:11:14 Log Type = 01
Log 1D - Health 0000 - HlthDtl 0000 - Time = 00:26:26 Log Type = 01
Log 1E - Health 0000 - HlthDtl 0000 - Time = 00:41:45 Log Type = 01
Log 2A - Health 0000 - HlthDtl 0000 - Time = 00:26:54 Log Type = 01
Log DA - Health 0000 - HlthDtl 0000 - Time = 00:00:07 Log Type = 01
Log DC - Health 0000 - HlthDtl 0000 - Time = 00:00:08 Log Type = 01
Log D6 - Health 0000 - HlthDtl 0000 - Time = 00:00:05 Log Type = 01
Log D7 - Health 0000 - HlthDtl 0000 - Time = 00:00:05 Log Type = 01
Log D8 - Health 0000 - HlthDtl 0000 - Time = 00:00:05 Log Type = 01
Log D9 - Health 0000 - HlthDtl 0000 - Time = 00:00:08 Log Type = 01
Log 56 - Health 0000 - HlthDtl 0000 - Time = 00:38:44 Log Type = 01
Log B0 - Health 0000 - HlthDtl 0000 - Time = 00:00:41 Log Type = 01
Log B1 - Health 0000 - HlthDtl 0000 - Time = 00:00:42 Log Type = 01
Log B2 - Health 0000 - HlthDtl 0000 - Time = 00:00:28 Log Type = 01
Log 0B - Health 0000 - HlthDtl 0000 - Time = 00:00:14 Log Type = 01
Log 7D - Health 0000 - HlthDtl 0000 - Time = 00:00:30 Log Type = 01
Log 58 - Health 0000 - HlthDtl 0000 - Time = 00:04:47 Log Type = 01
Log 08 - Health 0000 - HlthDtl 0000 - Time = 04:37:43 Log Type = 02
Log 0C - Health 0000 - HlthDtl 0000 - Time = 01:04:00 Log Type = 02
Log 0D - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 01
Log 40 - Health 0000 - HlthDtl 0000 - Time = 00:31:48 Log Type = 01
Log 31 - Health 0000 - HlthDtl 0000 - Time = 00:31:39 Log Type = 04
Log 32 - Health 0000 - HlthDtl 0000 - Time = 00:30:25 Log Type = 04
Log 33 - Health 0000 - HlthDtl 0000 - Time = 00:00:06 Log Type = 04
Log 34 - Health 0000 - HlthDtl 0000 - Time = 00:00:06 Log Type = 04
Log 36 - Health 0000 - HlthDtl 0000 - Time = 00:00:01 Log Type = 02
Log 37 - Health 0000 - HlthDtl 0000 - Time = 00:00:01 Log Type = 02
Log 26 - Health 0000 - HlthDtl 0000 - Time = 00:22:36 Log Type = 01
Log 3A - Health 0000 - HlthDtl 0000 - Time = 02:08:54 Log Type = 02
Log 0A - Health 0000 - HlthDtl 0000 - Time = 00:05:18 Log Type = 01
Log 8A - Health 0000 - HlthDtl 0000 - Time = 00:01:16 Log Type = 01
Log 3B - Health 0000 - HlthDtl 0000 - Time = 00:00:21 Log Type = 02
Log 3C - Health 0000 - HlthDtl 0000 - Time = 00:00:18 Log Type = 02
Log 3D - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 02
Log 3E - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 02
Log A9 - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 01
Log 3F - Health 0000 - HlthDtl 0000 - Time = 00:00:22 Log Type = 01
Log 09 - Health 0000 - HlthDtl 0000 - Time = 00:10:02 Log Type = 01
Log 20 - Health 0000 - HlthDtl 0000 - Time = 00:11:12 Log Type = 01
Log 77 - Health 0000 - HlthDtl 0000 - Time = 00:02:58 Log Type = 01
Log 43 - Health 0000 - HlthDtl 0000 - Time = 00:23:50 Log Type = 01
Log 27 - Health 0000 - HlthDtl 0000 - Time = 00:06:01 Log Type = 01
Log B3 - Health 0000 - HlthDtl 0000 - Time = 00:00:41 Log Type = 01
Log B4 - Health 0000 - HlthDtl 0000 - Time = 00:00:43 Log Type = 01
Log B5 - Health 0000 - HlthDtl 0000 - Time = 00:00:29 Log Type = 01
Log 51 - Health 0000 - HlthDtl 0000 - Time = 00:11:26 Log Type = 01
Log 48 - Health 0000 - HlthDtl 0000 - Time = 01:03:31 Log Type = 01
Log 41 - Health 0000 - HlthDtl 0000 - Time = 00:05:28 Log Type = 01
Log 49 - Health 0000 - HlthDtl 0000 - Time = 00:58:53 Log Type = 01
Log 4B - Health 0000 - HlthDtl 0000 - Time = 00:10:45 Log Type = 01
Log 4A - Health 0000 - HlthDtl 0000 - Time = 00:00:33 Log Type = 01
Log 4D - Health 0000 - HlthDtl 0000 - Time = 00:00:48 Log Type = 01
Log 39 - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 01
Log 22 - Health 0008 - HlthDtl 000F - Time = 00:00:26 Log Type = 01
Log 61 - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 02
Log 28 - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 01
Log 62 - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 02
Log 29 - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 01
Log 63 - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 02
Log 59 - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 01
Log B6 - Health 0000 - HlthDtl 0000 - Time = 00:00:41 Log Type = 01
Log B7 - Health 0000 - HlthDtl 0000 - Time = 00:00:42 Log Type = 01
Log B8 - Health 0000 - HlthDtl 0000 - Time = 00:00:29 Log Type = 01
Log 6F - Health 0000 - HlthDtl 0000 - Time = 00:00:37 Log Type = 01
Total Cert Time = 20:54:00
T>nterface task reset
              Spin Ready
(P)SATA Reset
Restore
PostPosted: August 12th, 2012, 11:09
Wrong boot ROM message (1-disk), it should be (perhaps) 2-disks - 4 heads
Am i right?
PostPosted: August 13th, 2012, 9:06
Any help?
Could you tell me if this script is right when i apply power?
Or if the right script should be this?
PostPosted: August 13th, 2012, 16:39
Thank you for your help SAjunky.
This is the terminal log:
              Spin Ready
(P)SATA Reset
Restore
T>/1
1>N1
Initializing SMART Sectors...................................RPO................
......ENDOK
1>
After the RPO message it did 2 horrible GRRRRRZZ noises (long about 4/5 secons for each), and i was very worried when i heard those, but after i rebooted i was very surprised.
BIOS detect it again, and also windows, and i can access to all my data again.
You're great Sajunky, you're the best and the only one in this forum who really helped me to recover something
:lol: :lol: :lol:
I don't understand why the famous gurus in this forum could not figured a way to solve this issue.
Maybe because they don't want to help... :roll:
It was easy. 8)
Solution:
you can safely reset SMART. Terminal command is to restart firmware ^T, after startup message ^Z (don't wait too long), go level 1 and issue command N1, like this:
^T
^Z
T>/1 [ENTER]
1>N1 [ENTER]
Thanks also to disk-imager.com
http://www.disk-imager.com/data-recovery-blog/?p=385
PostPosted: August 13th, 2012, 16:54
Whooooow!!!!
I am humble man. Why you don't say all truth?
It was your findings, not mine. You posted this link in private message, why don't share with others? Here it is:
Anyway, I am glad it worked. :)
EDIT: I see, link is already included.
PostPosted: August 13th, 2012, 16:58
I did, now i'm sharing the link. :wink:
But i must thank you, because you were able to understand better then me what is write in the link above.
The solution in there was not so explicit for me :)
PostPosted: November 17th, 2012, 13:34
Nooo SAjunky has been banned.
Why? :shock:
I wanted to ask you something of important :?
PostPosted: November 18th, 2012, 5:31
Why? :shock:
Yes , but don't know Why?
Why??
Users browsing this forum: Google [Bot] and 113 guests
