 Post subject: WDC WD20EARS-00MVWB0 read SA, but dont read user area
PostPosted: October 10th, 2012, 15:44
If i want read any LBA, hdd respond Read error (48-bit) HDD readines timeout (10000) ms.
Check SA all ok, modules can read/write, but user area not readable.
Modules directory address............... : 377 653 (24)
SA regions address...................... : by default
SA Translator loading................... : Ok
Heads number............................ : 6
Heads number in use..................... : 6
Switched off heads...................... : No
Heads map............................... : 0,1,2,5,6,7
ROM Firmware version.................... : 00250012
Service area:
SA dir reading (ID)..................... : Ok
SA Access............................... : Copy 0,Copy 1
Configuration reading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
I search but at this time dont find solution, maybe somebody know that is a problem can be.........
thx
 Post subject: Re: WDC WD20EARS-00MVWB0 read SA, but dont read user area
PostPosted: October 10th, 2012, 16:21
maybe translator
PostPosted: October 10th, 2012, 16:30
31 module- i can read this module, but i'm not sure that he is good.
PostPosted: October 10th, 2012, 16:34
regenerate the translator
PostPosted: October 10th, 2012, 16:38
ok, i try.
sorry if my question stupid :) i novice in data recovery and dont want make more trouble
PostPosted: October 10th, 2012, 16:51
It could be a bad head.
Data Recovery Cape Town
PostPosted: October 10th, 2012, 16:55
Bingo! 8)
Or just too weak to allow proper translation initialisation.
PostPosted: October 10th, 2012, 17:00
pcimage wrote:
Bingo! 8)
i.e. SA read/write , but cant read from user area?
Heads test
Cylinder to test........................ : -10
Heads to test........................... : 0,1,2,5,6,7
Head 0.................................. : Ok
Head 1.................................. : Ok
Head 2.................................. : Ok
Head 5.................................. : Ok
Head 6.................................. : Ok
Head 7.................................. : Ok
PostPosted: October 10th, 2012, 22:50
I agree that sometimes heads test good, but may be too weak to activate the translator.
http://www.datasaversllc.com
PostPosted: October 11th, 2012, 6:13
but if weak etc. one or two head i can load loader and read from good head?
PostPosted: October 31st, 2012, 1:38
here this solution:
http://www.youtube.com/watch?v=n2ZBjqn1 ... e=youtu.be
DATA RECOVERY SERVICE VIETNAM
Cứu dữ liệu ổ cứng| Cứu dữ liệu máy chủ |Phục hồi dữ liệu
Users browsing this forum: Google [Bot] and 115 guests
