 Post subject: Seagate ST3320613AS has an error in terminal
PostPosted: December 3rd, 2012, 7:00
Seagate ST3320613AS firmware SD22 320Гб
Bios said
Master Hard Disk Error
In terminal have.
Without SATA connection to pc
(P) SATA Reset
PASSPackage Verified
ReadCap successful - set 48Bit <- Current = 2542EAB0RWSWD-OptChange: Ctrl 0001 D
vgas 0008 Rvgas 0008 Fvgas 0008 SumOf 0008
(P) SATA Reset
Package Verified
No Phy: Staggered spin bypass
After connection to SATA PC
Rst 0x10M
(P) SATA Reset
(P) SATA Reset
Package Verified
Send Status: COMRESET seen
ABORT!
SenseCode = 03310000
ReadyStatusFlags = 0002A1A5
ABORT!
ABORT!
ABORT!
If you have any tips tell me what to do.
thanks in advance
 Post subject: Re: Seagate ST3320613AS has an error in terminal
PostPosted: December 3rd, 2012, 7:48
It would be nice to know what did the client said about that drive.
Also, have you tested any parts?
PostPosted: December 3rd, 2012, 9:28
Exactly.
What was the story of the drive ?
PostPosted: December 3rd, 2012, 11:07
this hdd come to me from another hdd master
PostPosted: December 3rd, 2012, 11:10
What is a HDD Master????
PostPosted: December 3rd, 2012, 11:38
Sorry for my english.
I mean service Engineer
PostPosted: December 3rd, 2012, 13:05
To be honest I never saw:
But I think first of all I would test PCB and heads.
PostPosted: December 4th, 2012, 16:24
before every appearance of an error in the terminal, you can hear as the head moves.
How to check the head?
PostPosted: December 5th, 2012, 6:25
I did this commands
F3 2>/1
F3 1>N1
F3 1>/T
F3 T>
F3 T>i4,1,22
F3 T>m0,2,2,,,,,22
After has in terminal
User Partition Format 3% complete, Zone 00, Pass 00, LBA 00004AA5, ErrCode 000
00080, Elapsed Time 0 mins 30 secs
WriteCapInfo
Selection = 0000 CurrentCap 2542EAB0 HDACap 2542EAB0
No update: HDA EQ Current
CurrentHDA 2542EAB0 HDACap 2542EAB0 NativeCap 2542EAB0 48BitCap 2542EAB0 28BitCa
p 0FFFFFFF
NO Save
User Partition Format Successful - Elapsed Time 0 mins 30 secs
Zone re-format was skipped.
then restart power and have this
Rst 0x10M
(P) SATA Reset
Set Transfer Mode selected
Ultra DMA selected
InitiateMarkPendingReallocateRequest
RAW ON After Spinup for counter=0x00010000, BlkAddr=0x209F890A
Starting LBA of RW Request=23C1662A Length=FFFFFFFF
ProcessRWError -Read- at LBA 23C16823 Sense Code=43110081
InitiateMarkPendingReallocateRequest !
Unrecoverable Error Reported
ProcessRWError -Read- at LBA 23C167F4 Sense Code=43110081!
ProcessRWError -Read- at LBA 23C16810 Sense Code=43110081
ProcessRWError -Read- at LBA 23C16810 Sense Code=40000087
RAW Mode Sector Writes After Spinup Is Now OFF, End BlkAddr=0x00604168
And i have access to hdd disk
copy all info from that
But work with freezes.
Can anyone explain what this error means??
I will be thanks for any help from members.
PostPosted: December 5th, 2012, 6:39
logros wrote:
F3 T>i4,1,22
F3 T>m0,2,2,,,,,22
Do you even understand what the commands are for and potential risks with running them?
Does HDD show ID now? If it does can you open utility and load modules table?
PostPosted: December 5th, 2012, 7:26
F3 T>i4,1,22
F3 T>m0,2,2,,,,,22 - Erase G-list
Restore translator
InitiateMarkPendingReallocateRequest, Unrecoverable Error Reported
- Dodn't know what is this
In victoria hdd id can see.
What utility to load modules i must use?
PostPosted: December 5th, 2012, 7:32
Seek a professional. Its the safest move for your data.
PostPosted: December 5th, 2012, 8:17
data from drive iam allready moved
Users browsing this forum: Google [Bot], Nadira and 104 guests
