 Post subject: Tools to see filesystem in half of a RAID0?
PostPosted: September 14th, 2013, 19:46
I had two 7200.10 Seagate drives in a machine. The power supply in the machine died, so I tried moving them to another machine to read the data off, but one of the drives stopped working too. It has a clicking noise when it starts, so I assume the head is malfunctioning and this would require very expensive professional repair. I'm not sure if there was anything I hadn't backed up on the drives, so I'm unsure if it's worth it to me.
One of the drives is still working fine, and I grabbed an image off of it (just to make sure it doesn't die as well), so I have half the data, but I don't know of any way to view it.
I've heard there are mechanisms to view the filesystem structure (NTFS) and parts of the files with only half of the RAID0, and that there are multiple entries of the file listings, so I could likely piece together most of it. Does anyone have suggestions on tools that could do this? I assume that I could then pull out half of files, e.g. pieces of images or text files.
 Post subject: Re: Tools to see filesystem in half of a RAID0?
PostPosted: September 15th, 2013, 16:37
Use R-studio and create empty disk space for the second drive . Create raid0 array with need stripe set. You will see part of the data structure.
Angel Data Recovery
PostPosted: September 16th, 2013, 4:08
But if it's a RAID0, that will not help you to get data out, as you'll always miss the other half.
PostPosted: September 16th, 2013, 8:26
Unless your stripe block size was very large and your files very small, the odds of you getting more than a few text files and thumb nails recovered is very low. You really need the second drive for any hope of success.
Users browsing this forum: No registered users and 53 guests
