 Post subject: ST3500418AS turns into ST_M13FQBL after replacing PCB
PostPosted: January 23rd, 2013, 10:46
how will i recover it? do still have a chance to recover my damage hdd? what are the recovery lab here in the philippines.? please help me. pictures and videos there is very much important
 Post subject: Re: ST3500418AS turns into ST_M13FQBL after replacing PCB
PostPosted: January 23rd, 2013, 10:48
You miss something very important to transfer during PCBs changing.
PostPosted: January 23rd, 2013, 10:51
i did swapping the rom. and nothings i cant. see my hdd on desktop . what are the possibilities cause problem like this
PostPosted: January 23rd, 2013, 10:53
Post the patient PCB# and the donor#.
PostPosted: January 23rd, 2013, 10:56
and also the drive is detected on bios as 0 capacity...
PostPosted: January 23rd, 2013, 10:58
Is there a strange sounds, or sounds looks normal ?
PostPosted: January 23rd, 2013, 11:01
yup it sounds normal. and spindling . i did also using the HDD regenerator and seagate tools. it detect using that tools but shows up only 3.6 gb out of 500gb... and can't fix it .
PostPosted: January 23rd, 2013, 11:07
Most likely the drive partially initialized from ROM , also check SATA cables. You will need a pro help.
Good luck.
PostPosted: January 23rd, 2013, 11:13
can a rom damage? after a short circuit made by the board
Users browsing this forum: Google [Bot] and 68 guests
