 Post subject: Seagate Barracuda LP Green is not recognized in BIOS suddenl
PostPosted: December 28th, 2012, 12:38
I have a Seagate Barracuda LP Green 5900rpm HDD
S/N: 5YD15W0C
ST2000DL003
P/N:9VT166-300
F/W:CC31
Date:11243
Site:WU
after 1 year of use, last week when i take it to another PC to transfer data, it suddenly cant recognized in BIOS, i change to 3 PC, the same problem the pc is a litter longger to continue compare to a good HDD
then i google the issue and find this great Forum.
i bought the USB-TTL converter and follow the hep topic to try to fix it
ctrl-z
F3 T>
F3 T>/2
F3 2>Z
F3 2>U
F3 2>/1
F3 1>
F3 1>N1
F3 1>/T
F3 T>
F3 T>i4,1,22
POWER OFF wait 10s and POWER ON
ctrl-z
F3 T>m0,2,2,0,0,0,0,22
F3 T>m0,2,2,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00,  Max Iterations = 00, Max Certify Rewr
ite Retries = 0000
User Partition Format Successful - Elapsed Time 0 mins 00 secs
Zone re-format was skipped.
F3 T>m0,2,2,,,,,22
Max Wr Retries = 0D, Max Rd Retries = 0D,  Max Iterations = 01, Max Certify Rewr
ite Retries = 29D1
NOW IT IS THIS STATUS
Rst 0x40M
RW: Disc Ctlr Initialization Completed.
MC Internal LPC Process
(P) SATA Reset
User Data Base  00991DF8
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes:  4011985C  4011796C
Seg Write Preamble VBM start: 000010A7 end: 000010CE
  Footer - start: 000010D0 end: 000010F7
Seg Read Preamble VBM - start: 000010F9 end: 00001120
  Footer - start: 00001122 end: 00001149
Reconstruction: MCMT Reconstruction Start
  Max number of MC segments 22E0
Nonvolatile MCMT sequence number 00004D4E
[RSRS] 0DD4
Reconstruction: EXCEPTION: Segment Overall Sequence Number Mismatch
00001FE9 00000000
[MCMTWS]
Reconstruction Fail: Burly Case
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00001001
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00001001
MCMainPOR: Feature Disabled...
No HOST FIS-ReadyStatusFlags 0002A1E1
IT STILL CANT BE RECOGNIZED IN BIOS, PLEASE HELP ME.
if there is some step wrong?
 Post subject: Re: Seagate Barracuda LP Green is not recognized in BIOS sud
PostPosted: December 28th, 2012, 12:44
Its a shame you didnt find this forum first. You have cleared resident and non-resident GLIST, and translator has been reconstructed without taking into account these lists.
Admittedly there is still some problem (and LP are not so nice to work on) but you have just potentially complicated this recovery and compromised your data.
PostPosted: December 28th, 2012, 13:53
If it was for me I had already removed at least from this forum the threads about the "internet fix" for Seagate because this is another example of consequences of applying "one size fits all" solutions without a diagnose.
Anyway the problem was for sure elsewhere. But now....
PostPosted: December 28th, 2012, 17:00
You know? I had a bad feeling when I saw these terminal commands on this website and made a point of mentioning it at the time. They worked fine with most 7200.11 drives but the newer ones have different problems, the NRG module which was rarely used on 7200.11 is almost always containing entries on 7200.12 + I think a notice may need to be added to the solution on this site if one hasn't been already.
As far as Limax's problem goes, it is still possible to recover after NRG removal but expect to pay a lot more than you would have - it will require a lot of manual rebuilding of the NRG list and you may also have to kiss a lot of frogs before you get your prince. So make sure the company can fix (and has heard of) Non-Resident G list (NRG) and how to fix it. If they say they can only read up to a certain point, then they havent fixed the problem.
https://www.mjm.co.uk/
PostPosted: December 28th, 2012, 22:20
Banned User
What is the Non-Resident G list?
Difference between G-list and Non-Resident G-list?
PostPosted: December 29th, 2012, 1:27
thanks fellows.
First I ask a friend for help, he just successful fix the same issus with his 7200.11 500G HDD, he suggest me to try his way to fix my problem so i use the 7200.11 METHORD
also I google the methord in local language but there are all way to fix 7200.11 500G or 1T HDD, not ST2000DL003 experience,
my be i'm to eager to fix it so, doesnt careful enough
if there is some hope to fix, please tell, thank you again.
PostPosted: December 29th, 2012, 1:33
Not by you, I'm afraid.
PostPosted: December 30th, 2012, 5:31
1楼,如果你是华人,我用汉语跟你说,希捷7200.11以后的硬盘,包括2.5寸 5400.6 等等,还有现在出的DM系列,结构已经发生重大改变,尽量不要尝试m0指令,大部分会修复成满盘坏扇区甚至不认盘,而且修坏后有时用UDMA修复编译器功能修复也无效
PostPosted: December 30th, 2012, 7:10
That's very easy for you to say.
PostPosted: December 31st, 2012, 4:46
Non resident list includes entries that influence translator and on clearing translator becomes damaged. without translator logical addresses cannot be resolved and data cannot be reached. There is no way to 'restore' this list without lots of manual work to rebuild each individual record within it.
G-list has no influence on translation system.
PostPosted: December 31st, 2012, 7:42
Banned User
A drive with bad sectors could have some LBA adresses in G-list, but if there are not bad sectors the G-list should be empty, and what about the non-resident GLIST?
It's possible to rebuild the non-resident GLIST in hyperterminal with RS232/TTL and with knowledge without loosing data?
PostPosted: December 31st, 2012, 7:47
Assume one thing : if you trust what internet say , "SOMETIMES" you gain access to the drive but SCREW DATA...
I know some case where people thought that a TTL-RS232 and some googling could give them a lot of extra money and they had a lot of royal troubles, instead.
PostPosted: December 31st, 2012, 7:48
non resident list is generated at factory prior to any shipping. It does not contain defects identified after this time
PostPosted: December 31st, 2012, 7:51
Banned User
I know it's possible to fix the non-resident GLIST in terminal with command m0,8,2,,,,,22 but this will destroy all data
PostPosted: January 22nd, 2013, 12:46
thats very sad for me, i have to accept all data lose.
and come to resaler for 3 yrs warrenty.
PostPosted: February 2nd, 2013, 23:16
Banned User
Correct me if i'm wrong, the translator regeneration comand it doesn't always clears the Non-Resident G list.
Many times happen to fix the 7200.12 serie with m0,2,2,,,,,22 and all LBAs get again accessed:
http://www.microsofttranslator.com/bv.a ... 200-12.htm
PostPosted: February 2nd, 2013, 23:42
As long as you think it is 'translator regeneration' ...
Users browsing this forum: Majestic-12 [Bot] and 63 guests
