 Post subject: Seagate 2.5 ST98823A - Password
PostPosted: February 25th, 2013, 19:48
Hey everybody.
I'm fighting with this Seagate since 6 or 7 years. Now, it's time to start again. I need some data from it. And these are pretty important.
So, I have a terminal. I can get some info like:
Interface task reset
4096k x 16 buffer detected
MERC2 - 1_Disk    0.05   01
Buzz  - -20-06 15:53
Head Mask 07,02 - Switch to full int.
              Spin Ready
Dwell Cyl - 084F/0499/04BD
(P)DiskAccess ReadSector EC=43 at ffffffff.00.0006
PATA Reset
Master
T>
Is it possible to read the password? Or is it possible to deactivate it?
I know it's easier with SeDiv. I've asked the owner, but I can't afford it.
Could you help me with it, please.
Regards,
Daniel
 Post subject: Re: Seagate 2.5 ST98823A - Password
PostPosted: February 25th, 2013, 20:05
I don't now the price now. I was asking about 6 months ago. And I don't remember. Later I will check my archives on the other pc. Yes, I can pay for this help.
Thank you for the answer.
PostPosted: February 25th, 2013, 20:32
Did you definitely set an ATA password on that drive, and are you sure that is the only problem? If not, then what evidence are you using which makes you believe that is the problem?
I'm asking because although I don't claim to be an expert (my day job is in a different part of the industry), looking at that terminal output, there seems to be a different problem (which might make it appear that the drive is locked, even without that being the real problem - hence why I am asking those earlier questions).
PostPosted: February 25th, 2013, 20:36
The problem is the password. I set the password aroud 2006 i think. After some time, not using this hd I simply forgot this psw.
PostPosted: February 25th, 2013, 20:54
Thanks for the reply. Based on that terminal output I think you might now have an extra problem (drives can deteriorate over time), but I hope (for your sake) that I'm wrong. :) Good luck!
PostPosted: February 25th, 2013, 20:58
Thank you! I know it. I just made a copy of the newer disc. Also Seagate, and I pluged it after about 3 years. I can see it's not working like before.
PostPosted: February 26th, 2013, 1:43
That Ec=43 is definitely a lot worse problem than a lost password. Check with MHDD and see : at best it is stuck BSY... :mrgreen:
PostPosted: February 26th, 2013, 3:20
I've seen worse errors in terminal!
At least it's giving "Master" and reaching "T>" so chances are it is just password protected with some mild media degradation thrown in for good measure :-)
You have PM with details of a Danish guy who can almost certainly help you.
PostPosted: February 26th, 2013, 7:37
Thanx for the Pm's:) Im going to check it with MHDD.
Users browsing this forum: Majestic-12 [Bot] and 96 guests
