 Post subject: Two partitions joined in to one by accident
PostPosted: March 2nd, 2013, 11:19
A client has accidently joined two of his partitions in to one. Is it possible to recover data from the previous two partitions ? Or restore the previous two partitions ?
 Post subject: Re: Two partitions joined in to one by accident
PostPosted: March 2nd, 2013, 11:46
Thanks Spildit for the information.
By the way,the client himself did the mess and brought the HDD to our shop.
Spildit wrote:
If data is important, you migh consider to STOP playing with a clients drive and send it to a proper data recovery center, or ask help from someone here.
Since it's a logic issue it will be possible for someone to assist you even remotely. For instance, i could very well recover the data on the drive remotely, by the net, if you are willing to pay some $$$$$ and assuming you didn't over-write the data on the drive.
PostPosted: March 2nd, 2013, 14:38
Thanks a lot. Shall do as recommended.
Spildit wrote:
Restorer Ultimate Network Pro can be run over the network (even internet) so that you can recover your client files from your home even if you are on the other side of the world.
http://www.restorer-ultimate.com/
Users browsing this forum: Google [Bot], Rendersmith and 88 guests
