 Post subject: 100619769 HOW TO SHORT THIS PCB?
PostPosted: February 17th, 2013, 3:30
Check the PCB pic
http://data.stuartconnections.com/objec ... p=9733&i=1
It loops, cant stop to work in Terminal
LED:00000067 FAddr:00385378
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: 100619769 HOW TO SHORT THIS PCB?
PostPosted: March 25th, 2013, 1:34
I don't understand exactly what you want to do, but if you want to short the read channel, then look for two pairs of thin parallel traces running between the preamp and the MCU. One will be the read differential pair, the other the write pair.
In the photo, the two R/W pairs look like they may correspond to pins 3 & 4 and pins 7 & 8 from the left, on the top row of the preamp connector. I can't see any termination resistors, so I can't tell which is Read and which is Write.
If you wish to disable the EEPROM during power-up, then one way to do it would be to ground the Hold pin. Just make sure it isn't hardwired to the supply. Usually there will be a pullup resistor. Alternatively you could try grounding the Clock or Data pins. You can release the shorted pin after the board has powered up.
PostPosted: March 25th, 2013, 3:00
Spildit wrote:
Did you manage to solve it ?
Here is another identical case :
t9500424as-bsy-t25624.html
Maybe we can share knownledge ?
Best regards.
No, I didn't solve the case, I returned this one.
For shorting fzabkar may direct you to the right way
__________
THANK YOU
SHAHI
Users browsing this forum: Majestic-12 [Bot] and 76 guests
