Arny006 wrote:
Hello @ All,
I'm new here, don't know if it's the right place but, you can help me (maybe).
I Install Linux (in the passt) on the Samsung HE753LJ by previous uninstall of the packages "dmraid" & "libdmraid" from installation-USB-stick.
Now I cannot install Kubuntu 13.04 even using the mentioned trick.
1. Do you know if exist (maybe) a new firmaware for this HDD in order to can be seen by Linux-Installation?
2. Do you know any other trick/work-around to enable the detection from Linux-side?
Thanks in advance and best regards, Arny
FW not needed to do this.
Probably your kubunttu not reconnize partition system.
