 Post subject: Linux-Install on Samsung HE753LJ
PostPosted: April 18th, 2013, 7:34
Hello @ All,
I'm new here, don't know if it's the right place but, you can help me (maybe).
I Install Linux (in the passt) on the Samsung HE753LJ by previous uninstall of the packages "dmraid" & "libdmraid" from installation-USB-stick.
Now I cannot install Kubuntu 13.04 even using the mentioned trick.
1. Do you know if exist (maybe) a new firmaware for this HDD in order to can be seen by Linux-Installation?
2. Do you know any other trick/work-around to enable the detection from Linux-side?
Thanks in advance and best regards, Arny
 Post subject: Re: Linux-Install on Samsung HE753LJ
PostPosted: April 18th, 2013, 8:42
Arny006 wrote:
Hello @ All,
FW not needed to do this.
Probably your kubunttu not reconnize partition system.
PostPosted: April 18th, 2013, 14:30
Spildit wrote:
hhddrec wrote:
Arny006 wrote:
Hello @ All,
Agree !
This is NOT a firmware issue.
Try to 0-fill (format) the drive first and install the linux on the drive then.
0-fill (format): smart response!
Users browsing this forum: No registered users and 57 guests
cron
