 Post subject: st31000524as
PostPosted: June 13th, 2013, 15:34
good evening .
st31000524as terminal log is
Boot 0x40M
Spin Up[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 40125B28 40122F00
Seg Write Preamble VBM start: 0000204A end: 00002091
Footer - start: 00002093 end: 000020DA
Seg Read Preamble VBM - start: 000020DC end: 00002123
Footer - start: 00002125 end: 0000216C
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 00473126
[RSRS] 05A5
Reconstruction: Completed 0: HeadPtr was unwritten
[MCMTWS]
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00005141
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00005141
MCMainPOR: Feature Enabled...
Rst 0x40M
Spin Up
LED:000000BD FAddr:000058E4
the drive doesn't detect at all ..
any help will be appreciated ..
thank you
 Post subject: Re: st31000524as
PostPosted: June 13th, 2013, 16:54
Does not detect in what? or where?
It seem like you should be able to at least see ID. Firmware access, likely not yet.
PostPosted: June 14th, 2013, 16:25
drive doesn't detect on bios ..
and i can access asci mode if hitted ctrl+z before the
start to appear , after they appear , ctrl+z will do nothing
thank you
PostPosted: June 14th, 2013, 19:14
What about drive behavior after power on? No odd sounds?
Try testing heads before the error message locks the drive.
Do NOT write anything to the drive or alter the firmware except SMART.
These can be difficult to recover.
PostPosted: June 15th, 2013, 9:46
thanks again for your reply ..
the data is not important , i just need the drive ..
no odd sounds , normal hdd initial behavior ..
PostPosted: June 15th, 2013, 11:46
In those circumstances there are few common things to try. Have been discussed on the forum a lot.
PostPosted: September 12th, 2013, 14:43
u need to find the pins to short then u able to repair the hdd.
mail me i tell u the procedure .
thanks
waqasali766@hotmail.com
