Rather than starting a new topic, I'll post my question here hoping that @fzabkar will see it since as I am facing a similar issue.
Indeed, I would like to get a confirmation that my fix will not destroy everything...
The PCB of my Seagate has burned (Seagate Barracuda ST31000524AS 9YP154-304 JC4B 8035 - PCB ref : 100650117 REV A) ==> as you can see in the attached pics the +5V power is dead.
I've diag the following :
- when plugged to sata power, I get +12V on the big TVS and 0V on the smaller TVS ==> See the 2 red arrows in the pic (multimeter: black on GND, red on right terminal of each TVS).
- I've tested resistance between +5V TVS and +5V power **after** the damage zone (see yellow lines on the picture): 0 Ohms => I understand that PCB is still OK here.
Can you confirm that I can try the following fix : put a 2 small bulbs of solder in place of the 2 burned inductors ?
Maybe it is best to solder a wire directly between the 3 +5V and the TVS ?
In fact, some pics on the net show 2 inductors where some other show only 1 (like here
http://www.users.on.net/~fzabkar/HDD/ST ... S_wire.jpg). Does it change anything ?
EDIT: purpose of the fix is temporary (data recovery only).
