 Post subject: Welcome and little advice
PostPosted: October 23rd, 2013, 8:59
Hello from Italy, i'm Federico a little IT manager.
I need a little help for a WD20EARS-00MVWB0
Hearing the drive, it spins up but isn't recognized from bios or OS level.
A friend tells me that where a fw bug so i ordered a new PCB from internet. The only difference is in the PCB review (REV A vs PC1) and sellers says isn't important :\
I put the board on and tried to boot up, now the drive spin up and stop completely after two tries..
Any advice? Thanks for your time and have a good day!
 Post subject: Re: Welcome and little advice
PostPosted: October 23rd, 2013, 9:07
Take it to a DR company.
PostPosted: October 23rd, 2013, 13:49
See viewtopic.php?t=27109&p=185525#p185525
You might be lucky ...
As for PCB swaps, look for a chip at U12. This chip needs to be moved from patient to donor.
That said, it probably isn't a PCB issue.
PostPosted: October 23rd, 2013, 13:59
Thanks for the replies ;)
With the original PCB, drive wont be recognized but spins up perfectly .. i'll try cleaning method
With the buyed PCB, drive is recognized (driver-level) for a short time then after two spins it dies
With another PCB (found one of the same model, differs PCB REV), drive is recognized (driver-level) and spins perfectly
Which one do you prefer? eheh :D
PostPosted: October 23rd, 2013, 14:58
Sounds like you have either a fw problem, or a suspect/weak head in the drive. I very much doubt the PCB is at fault.
I suspect the PCB you bought either has a rom from different family drive in/on it, or the head map in ROM is different to your drive.
By fw problem I mean fw on the platters, not PCB. So not DIY :-(
PostPosted: October 24th, 2013, 7:21
Agree, a new PCB is not going to help you here.
Data Recovery Cape Town
Users browsing this forum: Google [Bot] and 81 guests
