 Post subject: WD20EARS-00MVWB0 sa access ?
PostPosted: January 15th, 2014, 7:16
Good morning ..
i have this
WDC WD20EARS-00MVWB00AB51
it's sadle G6
the drive had sa problems , head tests ok .
tried to refresh the sa area, so i took an original copy of the rom+rom modules+ modules + tracks ..
format sa , ok
now i can't access to the sa area to rewrite the mods or tracks , am using DFL
rewrite mod 1 and 35 failed !!
and am not able to write any mod or track ..
any idea will be appreciated ..
thanks
 Post subject: Re: WD20EARS-00MVWB0 sa access ?
PostPosted: January 15th, 2014, 8:23
first try to upload ata overlay 11 number module in ram . then upload 01 to rom .
then open module directory then upload 01 and 35 then reset power
now again connect hdd . now upload module 11 in ram . then open module directory and upload all modules .
if u not upload 11 module to ram ,u cannot access sa.
its permanant overlay module
PostPosted: January 15th, 2014, 12:43
thank you for the hint ..
am aware of this method , but , u can't upload a mod to ROM , there are onlly two new options in the new dfl program
upload modules dir to RAM and upload a module to RAM
and even after uploading 01 to RAM am still unable to access SA , and not able to write modules neither by id nor by aba
i would appreciate if u can take a look by teamviewer
PostPosted: January 15th, 2014, 14:28
What is the firmware revision of your drive?
There are two groups of F/W and the approuch should be different for each one of them.
PostPosted: January 15th, 2014, 15:27
it's
WDC WD20EARS-00MVWB0_51.0AB51_WD-WCAZAA437245_00200084_1980_256
PostPosted: January 17th, 2014, 7:48
Spildit wrote:
raven4d wrote:
Good morning ..
i have this
it's sadle G6
format sa , ok
thanks
Did you try hot swap ?
Bad sectors might have been found while doing the SA format, correct ? If so it might afect ROM module containing sa translator/defects.
I have never tested with this and sadle is a pain... If you do the hot swap the defects on the donnor sa will be diferent so most likely will not work either...
Interesting, interesting !
More testing is required.
The more i learn DR the more i realize how little i know...
thanks for the answer ..
indeded sadle is a pain ..
