 Post subject: How to resolve the "sector 0" problem
PostPosted: February 1st, 2014, 15:10
The problem in the hard drive
WD20EARX 2.0 TB
MDL:WD20EARX-00PASB0
When i pluged the hard drive in my computer
It seemed to me that he suffered Bad Sector .. i have used the HDD Regenerator
During the scan .. The program freezes and stops working
I got up close it through the Task Manager and when i restart .. The system did not boot .. I got up to separate the hard disk
After I've run the device. I connect the Hard again shows like undivided
When what I tried to split it .. Does not work and show me this message Sector 0 error
How can I solve this problem with the knowledge that I do not need the data on the hard drive
 Post subject: Re: How to resolve the "sector 0" problem
PostPosted: February 1st, 2014, 17:36
HDD Regenerator is useless. Period.
IF and only IF the "problem" is a "soft error" that goes away zerofilling the drive (use MHDD or so) , assuming you don't need the data on drive as you stated, it's good.
Otherwise the drive nneds to be professionally refurbished (if there is no other problem) OR replaced.
All this without professional tools.
PostPosted: February 2nd, 2014, 7:07
I use MHDD now It give me that
[PRE]
50 ERR INDX CORR DREQ DRSC WRFT DRDY BUSY    PWD AMNF T0NF ABRT IDNF UNCR BBK 00
[WDC WD20EARX-00PASB0  ] [3,907,029,168] [             ] [                   ]
PCI BUS ver: 3.0
PCI Last Bus: 235
NAME                            VEND  DEV   ADDR  ADDR
Intel <unknown>                 8086  1C00  F111  F101
Intel <unknown>                 8086  1C00  F0F1  F0E1
Intel <unknown>                 8086  1C08  F0B1  F0A1
Intel <unknown>                 8086  1C08  F091  F081
Primary channel enabled. To disable see MHDD.CFG
Autodetect enabled. To disable see MHDD.CFG
To get help press <F1> or type "HELP"
MHDD>ID
WDC WD20EARX-00PASB0  LBA:3,907,029,168  BIOS: 81H
SN:WD-WCAZAD103480   FW:51.0AB51   Size = 1907729MB
WARNING: THIS DRIVE IS LOCKED BY ATA PASSWORD
Is there any hope :(
PostPosted: February 2nd, 2014, 8:45
[PRE]
PCI BUS ver: 3.0
PCI Last Bus: 235
MHDD>ID
The hard now is unlocked but when use ERASE it say broken driver :(
PostPosted: February 2nd, 2014, 9:19
Could this be a virus problem?
http://www.datasaversllc.com
PostPosted: February 2nd, 2014, 9:53
Could be?
If could how i can fix it
I donot know how to use MHDD
I Disable Hard password by atapwd successful
Now how i can make it work again
I couldn't make partition table
best regards
PostPosted: February 2nd, 2014, 11:15
In mhdd (or other software) could you try to run scan from different positions.
Like scan from 1 000 000 to end sector
From 10 000 000 to end sector
From 50 000 000 to end sector
From 100 000 000 to end sector.
If it start with error from 1st sector of scan more likely you have some issue with bad(weak) head that is preventing the drive from LBA access.
DataRecovery.bg
PostPosted: February 2nd, 2014, 13:21
Frist, I apologize for my terrible English language
Socond I newbie
When I scan from any sector 1 or 50000 or 1000000 or any number always get error and !!!!!!!!!!!!!!!!!!!! from 0 to the last sector
when i search in
WD Support / Knowledge Base / Diagnostic Error Codes
Error code 581
Write Fault
When either writing zeros or relocating a sector, the Write command failed. Drive should be replaced
the Agent of Western Digital in our country refusal change the hard and say the Warranty is one year but its 3 years
PostPosted: February 3rd, 2014, 6:41
Unfortunately I did not found a professional in Riyadh, Saudi Arabia
They say only data retrieval service no hard disk fix
and I do not want to restore the data only want to make it work again
when use EID
[PRE]
50 ERR INDX CORR DREQ DRSC WRFT DRDY BUSY        AMNF T0NF ABRT IDNF UNCR BBK 00
MHDD>ID
MHDD>eid
Supports: LBA48 HPA DLMC LBA MS16 DMA (UDMA6,MWDMA2)
SMART: Enabled SelfTest: Supported ErrorLog: Supported
Security: high, OFF. Size = 1907729MB
| Help : <F1> and command MAN                                       | 10:07:42
[/PRE]
And when use scan from any sector
51 ERR INDX CORR DREQ DRSC WRFT DRDY BUSY        AMNF T0NF ABRT IDNF UNCR BBK 04
[WDC WD20EARX-00PASB0  ] [3,907,029,168] [    6,411,465] [  EST:    3:13:36  ]
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!  ACT [201436 kb/s]
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ° <3ms  :
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ± <10ms :
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ² <50ms :
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! غ <150ms:
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! غ <500ms:
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! غ >500ms:
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ? TIME :
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! x UNC  :
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ! ABRT :  25143
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! S IDNF :
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! A AMNF :
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 0 T0NF :
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! * BBK  :
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! [  0.2% ]  [  0.2% ]
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Error: 6410190
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Error: 6410445
!!!!!!!!!                                                   Error: 6410700
                                                            Error: 6410955
Last scanned LBA: 6411719                                   Error: 6411210
| Scan a drive : <F4>                                               | 10:15:46
[/PRE]
should i change scan Settings ?
can I try to reinstall firmware without tools with software only ?
the partition table is deleted if this info is important
SMART
[PRE]HDD: WDC WD20EARX-00PASB0; FW: 51.0AB51; SN: WD-WCAZAD103480
            Name                        Val Worst Raw
Att #   1 : Read error rate           : 200  200  5
Att #   3 : Spin up time              : 187  165  5616
Att #   4 : Number of spin-up times   :  96   96  4777
Att #   5 : Reallocated sectors count : 200  200  34
Att #   7 : Seek error rate           : 100  253  0
Att #   9 : Power-on time             :  91   91  7124
Att #  10 : Spin-up retries           : 100  100  0
Att #  11 : Calibration retries       : 100  100  0
Att #  12 : Start/stop count          :  98   98  2140
Att # 192 : Power-off retract count   : 199  199  1235
Att # 193 : Load/unload cycle count   : 168  168  98113
Att # 194 : HDA Temperature           : 122  104  28
Att # 196 : Reallocate event count    : 166  166  34
Att # 197 : Current pending sectors   : 200  200  2
Att # 198 : Offline scan UNC sectors  : 200  200  0
Att # 199 : Ultra ATA CRC Error Rate  : 200  200  0
Att # 200 : Write error rate          : 200  200  0
[/PRE]
If i want to buy a powerful hard drive
What is best to install the operating system
WD blue 1 TB
OR
WD Green 2 TB
OR
Seagate 2 TB
Thanks for helping
PostPosted: February 3rd, 2014, 8:55
The drive can be probably be fixed by pro (have an idea about whst's failing but without a complete diagnose it is just guessing).
The outcome may be a working drive or the 2TB has to be downgraded to a smaller capacity.
The only concern is the cost : maybe buying a new 2TB drive is simpler.
P.S. don't buy WD again, get smaller and less critical drives like Hitachi or Toshiba that are the same, or if you want enterprise class drives for whatever reason , look for Seagate. The smaller the better.
PostPosted: February 3rd, 2014, 11:44
I had a hard drive Samsung 500 GB, but it burned down due to the entry of the juice inside the pc accidental
Since 2 week ago and The operating system installed on it.
Now I have 2 HDD The frist HDD is WD Green 3.0 TB(free 100 GB) working well and The second HDD is Seagate 2.0 TB (free 600 GB) Heats up quickly
when I install operating system on it need to create a new partition on the beginning of HDD in 2.0 TB
how i can do it i cannot move or take a copy of my file For another place.
sorry for my bad english
Users browsing this forum: No registered users and 47 guests
