 Post subject: WINXP - disk read error - partition problem
PostPosted: April 17th, 2014, 3:20
I receive drive from customer that report "disk read error".
I image drive to another drive. Everything was OK and job was done OK. It was strange, that Ghost report that copy 476929MB of data. Drive capacity in ghost 476929MB.
When I connect destination drive to computer, it report same error.
I connect drive to working winxp PC over USB dock. Windows detect drive, show drive, but report disk read error. Size in properties is 0.
Is any good SW solution to fix partition and to image full drive.
 Post subject: Re: WINXP - disk read error - partition problem
PostPosted: April 17th, 2014, 3:33
Is it a 500GB drive? If so, then why should the reported capacity be strange?
PostPosted: April 17th, 2014, 3:42
Hello Mr. Zabkar,
it's 500GB drive.
Sorry. Ghost reported size of source and destination is 476940MB
Copied 476929MB
PostPosted: April 17th, 2014, 3:50
Is the capacity reported differently via the dock compared with a direct SATA connection?
PostPosted: April 17th, 2014, 4:13
Dear Mr. Zabkar,
I suspect, that something is wrong with partition table. It's strange, that Ghost copy full capacyty of data. Like that the disk is full of data. Normally it show data size on disk.
I can recover files, this is not problem.
But I would like to boot from this drive.
Thank you
PostPosted: April 17th, 2014, 5:19
Could we see sector 0?
PostPosted: April 17th, 2014, 5:56
Dear Mr. Zabkar,
sector 0
and sector 63
Thank you very much
PostPosted: April 17th, 2014, 6:35
The boot sector is indicating that the NTFS volume begins at sector 63 (= 0x3F) and has a size of 0x3A380D40 sectors.
The partition table has a single NTFS partition beginning at sector 63 and with a size of 0x3A380D41 sectors.
The partition size is ...
0x3a380d41 x 512 bytes = 476929.657 megabytes
I believe there should be a backup NTFS boot sector at sector 0x0x3A380D7F.
In short I can't see any problem.
PostPosted: April 17th, 2014, 8:36
size of source and destination is 476940MB Copied 476929MB
476940MB - 476929MB = 11MB
XP: could ths be down to Cylinder alignment ie XP default is Cyl, and wont use anything less than a full cylinder? or MebiByte v MegaByte?
On an XP machine at the minute and have around 10-11 MB space at the end of a drive.
K
Голод не тётка!
PostPosted: April 17th, 2014, 16:15
ISTM that 11MB is a little more than 1 cylinder.
255 heads x 63 sectors/track x 512 bytes/sector = 8 225 280 bytes
However, the partition does end on a cylinder boundary.
0x3A380D80 / 255 / 63 = 0xED80
It still doesn't explain the "disc read error" message, unless the dock is shrinking the physical drive.
PostPosted: April 17th, 2014, 16:45
Dear digitalferret and Mr. Zabkar,
there is unpartitioned space around 10MB(as digitalferret mentioned).
In Windows Disk management drive is healthy with correct size, but without file system.
Users browsing this forum: Majestic-12 [Bot] and 40 guests
