 Post subject: Seagate ST2000DL003 stays busy
PostPosted: April 29th, 2014, 6:52
Hi there!
I have a patient drive wich has dropped while it was powered.
After a head swap, the drive was identified fine with some strange beeping noise, and read some data, but there was so many CRC errors. (I use Atola Insight)
The terminal window post is:
Rst 0x40M
MC Internal LPC Process
FAIL Op=0165 Resp=0005
FAIL Op=0055 Resp=0005
FAIL Op=0065 Resp=0005
FAIL Op=0900 Resp=0005
FAIL Op=0600 Resp=0005
(P) SATA Reset
User Data Base 00991228
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 4011A58C 4011869C
Seg Write Preamble VBM start: 000010A7 end: 000010CE
Footer - start: 000010D0 end: 000010F7
Seg Read Preamble VBM - start: 000010F9 end: 00001120
Footer - start: 00001122 end: 00001149
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 22E0
Nonvolatile MCMT sequence number 00000BBA
[RSRS] 05E2
Reconstruction: Completed 0: MCMT Was Valid, HeadPtr was unwritten
[MCMTWS]
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00000041
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00000041
MCMainPOR: Feature Enabled...
FAIL Op=0555 Resp=0005
Then i cleared the smart with i4,1,22 command, reconstruct the translator with m0,2,2,0,0,0,0,22, and now the terminal post this, and the drive stays BUSY:
F3 T>
Rst 0x40M
(P) SATA Reset
User Data Base 00991198
MCMainPOR: Start:
Nonvolatile MCMT sequence number 00000BCE
[RSRS] 05E2
Starting LBA of RW Request=00033798 Length=000004EC
ProcessRWError -Read- at LBA 00033798 Sense Code=43110081
Reconstruction: EXCEPTION: Seg Read Fail: Status = 0000
ErrorSegmentOffset = 0000
Starting LBA of RW Request=0003381F Length=00000005
ProcessRWError -Read- at LBA 0003381F Sense Code=43110081
Status = 0000
Starting LBA of RW Request=0003381A Length=00000005
ProcessRWError -Read- at LBA 0003381A Sense Code=C4090082
Status = 0000
Starting LBA of RW Request=00033815 Length=00000005
ProcessRWError -Read- at LBA 00033815 Sense Code=43110081
Status = 0000
Starting LBA of RW Request=00033810 Length=00000005
ProcessRWError -Read- at LBA 00033810 Sense Code=43110081
Status = 0000
Starting LBA of RW Request=0003380B Length=00000005
ProcessRWError -Read- at LBA 0003380B Sense Code=C4090082
Status = 0000
Starting LBA of RW Request=00033806 Length=00000005
ProcessRWError -Read- at LBA 00033806 Sense Code=43110081
Status = 0000
Starting LBA of RW Request=00033801 Length=00000005
ProcessRWError -Read- at LBA 00033801 Sense Code=43110081
Status = 0000
Starting LBA of RW Request=000337FC Length=00000005
ProcessRWError -Read- at LBA 000337FC Sense Code=43110081
Status = 0000
Starting LBA of RW Request=000337F7 Length=00000005
ProcessRWError -Read- at LBA 000337F7 Sense Code=C4090082
Status = 0000
Starting LBA of RW Request=000337F2 Length=00000005
ProcessRWError -Read- at LBA 000337F2 Sense Code=C4090082
Status = 0000
Starting LBA of RW Request=000337ED Length=00000005
ProcessRWError -Read- at LBA 000337ED Sense Code=43110081
Status = 0000
Starting LBA of RW Request=000337E8 Length=00000005
ProcessRWError -Read- at LBA 000337E8 Sense Code=C4090082
Status = 0000
Starting LBA of RW Request=000337E3 Length=00000005
ProcessRWError -Read- at LBA 000337E3 Sense Code=C4090082
Status = 0000
Starting LBA of RW Request=000337DE Length=00000005
ProcessRWError -Read- at LBA 000337DE Sense Code=43110081
Status = 0000
Starting LBA of RW Request=000337D9 Length=00000005
ProcessRWError -Read- at LBA 000337D9 Sense Code=C4090082
Status = 0000
Starting LBA of RW Request=000337D4 Length=00000005
ProcessRWError -Read- at LBA 000337D4 Sense Code=C4090082
Status = 0000
Starting LBA of RW Request=000337CF Length=00000005
ProcessRWError -Read- at LBA 000337CF Sense Code=C4090082
Status = 0000
Starting LBA of RW Request=000337CA Length=00000005
ProcessRWError -Read- at LBA 000337CA Sense Code=43110081
Status = 0000
Starting LBA of RW Request=000337C5 Length=00000005
ProcessRWError -Read- at LBA 000337C5 Sense Code=C4090082
Status = 0000
Starting LBA of RW Request=000337C0 Length=00000005
ProcessRWError -Read- at LBA 000337C0 Sense Code=43110081
Status = 0000
Starting LBA of RW Request=000337BB Length=00000005
ProcessRWError -Read- at LBA 000337BB Sense Code=43110081
Status = 0000
Starting LBA of RW Request=000337B6 Length=00000005
ProcessRWError -Read- at LBA 000337B6 Sense Code=43110081
Status = 0000
Starting LBA of RW Request=000337B1 Length=00000005
ProcessRWError -Read- at LBA 000337B1 Sense Code=43110081
Status = 0000
Starting LBA of RW Request=000337AC Length=00000005
ProcessRWError -Read- at LBA 000337AC Sense Code=C4090082
Status = 0000
Starting LBA of RW Request=000337A7 Length=00000005
ProcessRWError -Read- at LBA 000337A7 Sense Code=43110081
Status = 0000
Starting LBA of RW Request=000337A2 Length=00000005
ProcessRWError -Read- at LBA 000337A2 Sense Code=C44400D1
Status = 0000
Starting LBA of RW Request=0003379D Length=00000005
ProcessRWError -Read- at LBA 0003379D Sense Code=43110081
Status = 0000
Reconstruction: EXCEPTION: Error in Header and ALL Footers.
Recon Last Chance
Starting LBA of RW Request=00033824 Length=00000001
ProcessRWError -Read- at LBA 00033824 Sense Code=C4090082 Header ID FFFFFFFF SeqNum FFFFFFFF
Reconstruction: EXCEPTION: Failed Final Recon Check: Burly Case
[MCMTWS]
Reconstruction Fail: Burly Case
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00001001
MCMainPOR: MCStateFlags = 00001001
MCMainPOR: Feature Disabled...
No HOST FIS-ReadyStatusFlags 0002A1E1
What did i wrong, and how could i solve this. I have very bad feelings :-(
 Post subject: Re: Seagate ST2000DL003 stays busy
PostPosted: April 29th, 2014, 8:02
Dropped while powered on = some sort of physical media damage.
Nobody can fix media damage, BUT try to work around it as much as possible.
PostPosted: May 13th, 2014, 12:50
Could someone help me to put this drive into working state? Please........ :oops:
PostPosted: May 13th, 2014, 14:37
The m0,2,2,,,,,22 is very dangerous for 7200.14 hard disk, specially if you need DATA from the drive.
If you run this command in OK working hard disk then it will destroy its translator and in return hdd not detect any more and shows a alot of bad sector.
FAIL Op=0165 Resp=0005 ============> This error means Head failling to read, and hdd give you little noise.
Starting LBA of RW Request=00033798 Length=000004EC ============> Read write fail at 33798 LBA (LBA is in hex)
Reconstruction: EXCEPTION: Seg Read Fail: Status = 0000 =========> repairing failed
Reconstruction: EXCEPTION: Error in Header and ALL Footers. ==========> built in design in firmware. Try to repair fault but failed
Recon Last Chance ========> Last retry to repair fault.
Starting LBA of RW Request=00033824 Length=00000001 =======> but again bad sector appear..
Reconstruction: EXCEPTION: Failed Final Recon Check: Burly Case ========> Result after try and try and try by firmware.
[MCMTWS]
Reconstruction Fail: Burly Case ====== ?
No HOST FIS-ReadyStatusFlags 0002A1E1 ============> failed to read firmware in simple words. If this msg appear then you need to use m0,2,2,,,,,22 command other wise not use this in 7200.14 series.
Solution
Follow these steps
1. power on and wait terminal log
2. when you power on you see spin up message in terminal. and after hdd calibrating complete you see spin up message again,
short read channel points immediately and remains shorted until it start giving message like unknown type or like this (No HOST FIS-ReadyStatusFlags 0002A1E1)
3. IF it show after few minutes (No HOST FIS-ReadyStatusFlags 0002A1E1) then use m0,2,2,,,,,22 then clear smart and reset power. and if it shows alot of error like QV qv qv qvqv qvq vqvq vqvq then don't worry just power off and on it will auto calculate translator bulk capacity and auto remove BULK error.
4. use congen to stop relocation of bad sector and disable smart
F00A2,00,22
F01E4,00,22
F057C,043C,22
these command work on level T .
clear smart
problem solved
Waqas Ali
www.sediv.net
PostPosted: May 13th, 2014, 15:52
Spildit wrote:
Maybe the platter got damaged/scratched.
Did you try to reverse clone or clone from the end to the start if Atola have that option ?
Also did you check the platters for damage ? You might end up damaging the heads when they reach the bad area of the platter.
Do you have module access ? Can you copy modules or tracks ?
First, thanks for the answer, and your questions!
The Atola Insight can imaging reverse, and is tried it, with o success.
While head swap i can only see the top platter, and there was some scratch under the parking ramp at the outer area of the platter.
...and i don' have tool for acces to SA modules, and as i know the Sediv coud not be access to these drives :-(
PostPosted: May 13th, 2014, 16:06
Thank you Ali, i will try it tomorrow.
Are these the read channel test points that i have to short after the drive spins up?
<a href="http://www.kepmegoszto.com/201405132200/537279eb650a5-unnamed.html" alt="www.kepmegoszto.com"><img src="http://v537279eb650a5.kepmegoszto.com/201405132200/t-537279eb650a5-unnamed.gif" alt="www.kepmegoszto.com"/></a>
PostPosted: May 14th, 2014, 4:22
Now the drive identified, but cannot read any sector :-(
Rst 0x40M
(P) SATA Reset
MCMainPOR: Start:
Nonvolatile MCMT sequence number 00000000
[RSRS] 0000
Starting LBA of RW Request=00000000 Length=000004EC
ProcessRWError -Read- at LBA 00000018 Sense Code=43110081
ErrorSegmentOffset = 00C0
Continuing after error
[MCMTWS]
(S) SATA Reset
PostPosted: May 14th, 2014, 5:36
F3 T>V1
User Slip Defect List
Head 0: entries 85B slips 103F
Head 1: entries 465 slips 872
Head 2: entries 372 slips 78B
Head 3: entries 2CD slips 77E
Head 4: entries F8F slips B55C
Head 5: entries 159 slips 886
Total Entries 23E7 Total Slips E59C
F3 T>/7
F3 7>X
Head 00 Resistance 0105
Head 01 Resistance 00FC
Head 02 Resistance 0103
Head 03 Resistance 0129
Head 04 Resistance 00F3
Head 05 Resistance 0102
F3 7>
PostPosted: May 14th, 2014, 5:38
I think there ar some bad sectors while reading FW.
So the conclusion is the System Area is damaged after the drive was dropped while it is powered :-(
PostPosted: May 14th, 2014, 6:21
Does the drive identify with correct capacity?
PostPosted: May 14th, 2014, 7:13
Yes, and can read smart data, and it's identified as: ST2000DL003-9VT166 / 5YD5TH47
When i would like to read ANY sector, the terminal sends: ProcessRWError -Read- at LBA 00F8C514 Sense Code=C4090082
I don't know is it important, but the PCB board is not the original one. The original PCB board has SH6968 motor controller chip, and now the assembled PCB board has a Smooth controller chip. I think this is not so important in this case.
PostPosted: May 14th, 2014, 8:22
The media seems damaged/deteriorated based on the errors posted.
BUT more concerning is your statement of PCB not being original. If this is the case, do you have the drive's native/original ROM?
Or probably you mean, the PCB you are currently testing the drive with (current mounted PCB on the drive at the time these tests were ran) is not the original?!?
PostPosted: May 14th, 2014, 8:50
Yes of course, the ROM is the drive's original ROM, and it's sits on the head stack donor's PCB. The original PCB has a short circuit, and does not spins up the drive.
I the past with another head stack, the drive was accessible, and after so many reading errors the Atola Insight restarted the drive, and it was no more identified still i made another head swap. The drive was readble with errors, and after i did m0,2,2,,,,,22 command, then the drive was stays busy with so many terminal errors.
Then shorted the read channel test points with m0,2,2,,,,,22 command, and now the drive works, but does not access any sectors.
When i start the drive, the terminal window says this:
Rst 0x40M
(P) SATA Reset
MCMainPOR: Start:
Nonvolatile MCMT sequence number 00000003
[RSRS] 0000
ProcessRWError -Read- at LBA 0000000F Sense Code=C3160080
ProcessRWError -Read- at LBA 00000010 Sense Code=C3160080
ProcessRWError -Read- at LBA 00000011 Sense Code=43110081
ErrorSegmentOffset = 0088
[MCMTWS]
Rst 0x40M
(P) SATA Reset
MCMainPOR: Start:
Nonvolatile MCMT sequence number 00000004
[RSRS] 0000
ErrorSegmentOffset = 0080
[MCMTWS]
When i want to read example sector 0, then terminal says:
Starting LBA of RW Request=00F8C514 Length=FFFFFFFF
Starting LBA of RW Request=00F8C614 Length=FFFFFFFF
ProcessRWError -Read- at LBA 00F8C614 Sense Code=C4090082
PostPosted: May 14th, 2014, 9:02
...and the donor drive had a same FW (CC45) and site code (WU)
The PCB printed number also was the same, but the motor controler chip is different. I think it's does not matter.
PostPosted: May 14th, 2014, 9:29
ok, your posts make a whole lot more sense now that you provided so much more info.
I doubt that you will make more progress on this drive going forward, but some things to check are:
1) that the reallocation was actually disabled (sometimes this does not happen despite issuing the commands to do so)
2) translator is good
3) build heads map and check LBA access per each head manually
P.S. I believe that whoever had this drive (owner maybe) kept powering the snut out of that drive after being dropped, which in my interpretation caused heads damage, media damage, and in attempt to read anything the PCB got blown = worst situation ever for customer and for those trying to recover the daters. Waste of time, money and nerves. Only a bit of common sense and refrain can go a long way on behalf of the customer. Sad.
Best wishes
PostPosted: May 19th, 2014, 7:25
Best wishes
Thank You labtech!
I have one new error message:
While imaging with Atola, and pushing the "Next Head" button that force the drive to read from the next head, the "Error reading head configuration from the disk." message appear on the Atola window, and the imaging is stops. So i think the head map is corrupt.
PostPosted: May 19th, 2014, 12:44
saltwater wrote:
Or the translator
PostPosted: May 19th, 2014, 13:40
labtech wrote:
saltwater wrote:
Or the translator
The "m0,2,2,,,,,22" command did not solved this problem, but since i was used this command first time in this driive, then all sectors are gone.
The head test now shows this:
F3 7>X
Head 01 Resistance 00FE
Head 02 Resistance 0108
Head 04 Resistance 00F5
Head 05 Resistance 0104
With V40 and V1 command i can read the G-List, and translator from the SA with no error.
PostPosted: May 19th, 2014, 14:13
Now if your drive access firmware and not gives access to user area , follow this
m0,2,2,,,,,22
/1
N1
power reset
/t
F00A2,00,22
F014E,00,22
F057C,043C,22
power reset
these three commands are used to disable smart and auto relocation.
now all sectors Access easily..
Software is just a plate form to diagnose a hard disk. main thing is your mind which give you idea to perform several tricks to repair hdd.
Waqas Ali
www.sediv.net
PostPosted: May 19th, 2014, 14:15
After use of m0,2,2,,,,,22 command always use clear smart, other wise all sector goes inaccessible.
If terminal shows this error (ProcessRWError -Read- at LBA 00F8C514 Sense Code=C4090082) then not worry about that, it is auto relocation system by firmware.
if you have any cloning tools like pc3000 and MRT try to disable smart option and try to clone the hdd with OK heads.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 65 guests
