 Post subject: what is a problem
PostPosted: September 5th, 2014, 11:11
��@����v\v\v\v\t\v\v\v\v\v^v^v^v^v^v\v\v\v^v^v^
 SIM Errob 1002
(P) SAT@ Reset
S
Error 1002v^v^v^v^v^v^v\v^v^v^v^v^v^v^v^v^v^v^v^v^
SIM Error 1002 PASSv^v^v^v^v^v^v^v^v^v^
RW: Error processing Performance Parameter File: 2 3C
(DOS)STE OUGHT: 0x00619B70 - 0x006206AF
(DOS)CMP
(DOS(STE OQGHT: 0x0062 6B0 - 0x0062682F
(DOS)CMP
(DOS)SPE OUGHT: 0x005F6FB0 - 0x005FDAEF
(DOS)CMPv^v^v^v^v\v^v^v\v^v^
(DOS)STE OUGHT: 0x005FDAF0 - 0x00603C6F
(DOS)CMP
(DOS)STE OUGHT8 0x064C3643 - 0x064C9DE6
 Post subject: Re: what is a problem
PostPosted: September 5th, 2014, 11:47
omg at least write what HDD you have :roll:
First of all, there are very weird characters in terminal probably caused by some voltage problems in connection between UART and HDD, or voltage problems in HDD itself :?
PostPosted: September 5th, 2014, 12:03
I know its a Seagate ;-) does that narrow it down ?
PostPosted: September 5th, 2014, 12:07
What is a problem?
prob·lem
ˈpräbləm/Submit
noun
1.
a matter or situation regarded as unwelcome or harmful and needing to be dealt with and overcome.
"mental health problems"
synonyms: difficulty, trouble, worry, complication, difficult situation; More
a thing that is difficult to achieve or accomplish.
"motivation of staff can also be a problem"
2.
PHYSICSMATHEMATICS
an inquiry starting from given conditions to investigate or demonstrate a fact, result, or law.
PostPosted: September 5th, 2014, 17:54
After seeing numerous terminal logs of this type, I've come to the conclusion that people omit the ground wire because they don't understand its importance.
PostPosted: September 6th, 2014, 4:43
 SIM Errob 1002
(P) SAT@ Reset
S
(DOS)CMP
(DOS)CMP
(DOS)CMP
Problem IS :
(1) SIM Error 1002 PASS
(2) RW: Error processing Performance Parameter File: 203C
(3) (DOS)STE OUGHT: 0x00619B70 - 0x006206AF
(4) (DOS)CMP
(5) u need get access in my mind.
(6) u need get access in my mind.
Yours Friend.
Jignesh Pankhania.
PostPosted: September 7th, 2014, 17:48
Hi Fran
What you want to say
PostPosted: September 7th, 2014, 20:21
He is saying that the ground wire is important even though the circuit seems to work without it. Some people don't connect it not realising this.
PostPosted: September 8th, 2014, 4:26
Hi HaQue!
Thanks 4 your quick response.
are you speaking about terminal GND? or what GND?
PostPosted: September 8th, 2014, 10:47
just connect ground of UART (RS232-TTL adapter or whatever you call it ) to HDDs ground (pin next to RX and TX pins, or ground from power supply, it should not matter, they are connected together).
PostPosted: September 8th, 2014, 10:56
Thaks Jano, i wsas not sure about what HaQue and other was speaking
so many thanks
Users browsing this forum: Google [Bot], Rendersmith and 42 guests
