 Post subject: Head replacement for a Samsung Momentus-B ST1000LM024
PostPosted: September 15th, 2014, 13:47
Dear experts,
Could anyone tell us if he succeed a head replacement for a Samsung Momentus ST1000LM0024 drive.
PC3000 support told me that it's very difficult to find a donor drive for head replacement.
Should I match the 3 first characters form the serial number?
Thanks in advance for your help
 Post subject: Re: Head replacement for a Samsung Momentus-B ST1000LM024
PostPosted: September 15th, 2014, 14:21
That's the rule for a Seagate. I don't believe it applies to a Samsung HDD.
See http://www.donordrives.com/hard-drive-pcb-donor-match
What did Ace Lab suggest?
PostPosted: September 15th, 2014, 15:06
Thank you very much for your reply.
They said that I have to mach :
1. Full Model Number. Example: ST1000LM0024
2. Site Code. Example: TK, AMK, KRATSG, WUXISG
3. Full part number or first 3 characters in serial number. Example: 9Y7389-301, 9JU138-302, 5MA84KC2, 9ND29XWG
4. Firmware. Example: CC44, 0005HPM1
It's the same parameters as http://www.donordrives.com/hard-drive-pcb-donor-match
PostPosted: September 15th, 2014, 15:07
They said also that it succeed in 20% of cases ONLY because it's very difficult to match a donor forthe Momentus family HDD.
PostPosted: September 15th, 2014, 15:21
That's wrong, those criteria are Seagate related. As fzabkar said, these are Samsung drives.
You have PM.
PostPosted: September 15th, 2014, 16:31
Thank you very much for you help.
But I'm confused. It's a Samsung drive but the family is Momentus (Seagate drive) and the Model number seems to be a Seagate model (STXXXXXX)
Should I refer to Seagate conditions or Samsung conditions to choose a donor drive.
PostPosted: September 15th, 2014, 16:36
Check the part number, PCB, serial number, firmware version. Any of these will distinguish a Seagate from a rebadged Samsung.
PostPosted: September 15th, 2014, 17:13
The PCB is a dead giveaway.
We replace heads in these without undue difficulty.
I'd take a hard look at the P/N and the first part of the S/N for head matching.
Jono
http://www.datasaversllc.com
PostPosted: September 18th, 2014, 0:55
i would agree with FZABKAR.
Its a SAMSUNG drive.
PostPosted: September 18th, 2014, 4:31
It's a Samsung drive despite of the label. Seagate acquired part of the Samsung's magnetic media division, that's the reason you see mixed Seagate and Samsung drives.
We've successfully replaced heads for these drives; the main problem is to find preamp compatibility (you can tell this from the terminal log), and the other thing is the poor quality of the heads they come with, or maybe the overall quality of the drive, that may bring problems when imaging the data.
Users browsing this forum: sixsweets and 41 guests
