 Post subject: can someone help me with my reports?
PostPosted: September 25th, 2014, 15:00
can someone told me if this reports are corrects please?
 Post subject: Re: can someone help me with my reports?
PostPosted: September 25th, 2014, 15:50
They look perfectly fine to me.
PostPosted: September 25th, 2014, 15:51
a disk give me error input parameters disk
and the smart
199 UltraDMA CRC Error Count 200 057 00000000-53C7 000
PostPosted: September 25th, 2014, 16:05
Growing C7 attribute usually indicates an interface problem of some kind.
Most likely that means a cable is better to be replaced. Also could be PCI/PCI-E bus overclocking or bad contact at SATA connector on drive or motherboard/controller.
First error sounds a bit strange to me, but can be a result of the OS switching channel mode to PIO.
PostPosted: September 25th, 2014, 16:09
If the drive has a jumper to limit the SATA link rate, then try that.
PostPosted: September 25th, 2014, 16:15
sorry I cannot upload it
how can I do that?
PostPosted: September 25th, 2014, 17:24
Copy the results to the clipboard in text mode and paste them into your next post. Use the "code" style button for proper formatting.
IMO CrystalDiskInfo provides a much friendlier and more logical output format (Text Copy).
PostPosted: September 25th, 2014, 17:38
PostPosted: September 25th, 2014, 17:41
I tried this
PostPosted: September 25th, 2014, 18:24
Try installing the OPT1 jumper.
http://www.wdc.com/en/library/eide/2579-001037.pdf
