 Post subject: My passport empty
PostPosted: October 9th, 2014, 14:30
Hi
I tried to access my passport hdd(WBGMT0010BAL-05) with password, after 3 times failed to access it i got empty hdd without password .
Pls your advice to recover my data.
regards
 Post subject: Re: My passport empty
PostPosted: October 10th, 2014, 10:58
Smartware will wipe the drive if the password in entered incorrect 3 times, likely is what happened, if so, no recovery possible.. IMHO
PostPosted: October 10th, 2014, 15:32
The user must agree to erasing the drive before this happens. SmartWare will not erase the drive without user permission.
Setting up security to lock or unlock a WD external drive with WD SmartWare Version 1.6.x and earlier:
http://wdc.custhelp.com/app/answers/det ... -smartware
If you enter the wrong password 5 times, you will receive the screen below. In order to try your password 5 more times, you will need to safely eject the drive and unplug both the power and data cable from the unit. Then plug it back it. You will now be given 5 more tries before you get the below screen again.
Users browsing this forum: No registered users and 48 guests
