I have a problem with my WD5000BMVW 11AMCS0 with PCB 2060-771737-000 (Inside a WD My Passport Essential USB 3 WDBACY5000ABL-EESN)
- Drive shows up in device manager (
http://i.imgur.com/wfoPBAO.png)
- LifeGuard Diagnostics says the drive have a good smart status (
http://i.imgur.com/J1rNzYk.png)
- The drive seems to spin fine, no ticking noise.
But it doesn't shows up in the "disk manager", I can't run "quick test" from LifeGuard Diagnostic.
I have a lot of the errors in the windows event log :
"An error was detected on device \Device\Harddisk7\DR2198 during a paging operation."
"The IO operation at logical block address 0x5fdb80 for Disk 7 (PDO name: \Device\00001b4f) failed due to a hardware error."
Do you think it's a PCB issue ? If so, can I just swap the PCB with a new one, or does it require ROM transfer ?
Thank you in advance !
