 Post subject: Recovery of a WD5000BMVW (WD My Passport Essential)
PostPosted: November 9th, 2014, 9:14
I have a problem with my WD5000BMVW 11AMCS0 with PCB 2060-771737-000 (Inside a WD My Passport Essential USB 3 WDBACY5000ABL-EESN)
- Drive shows up in device manager (http://i.imgur.com/wfoPBAO.png)
- LifeGuard Diagnostics says the drive have a good smart status (http://i.imgur.com/J1rNzYk.png)
- The drive seems to spin fine, no ticking noise.
But it doesn't shows up in the "disk manager", I can't run "quick test" from LifeGuard Diagnostic.
I have a lot of the errors in the windows event log :
"An error was detected on device \Device\Harddisk7\DR2198 during a paging operation."
"The IO operation at logical block address 0x5fdb80 for Disk 7 (PDO name: \Device\00001b4f) failed due to a hardware error."
Do you think it's a PCB issue ? If so, can I just swap the PCB with a new one, or does it require ROM transfer ?
Thank you in advance !
 Post subject: Re: Recovery of a WD5000BMVW (WD My Passport Essential)
PostPosted: November 9th, 2014, 12:30
edit: PCB 2060-771737-000 REV P1
PostPosted: November 9th, 2014, 12:57
Hard to say without proper diagnose.
You can't just swap PCB. You need ROM transfer.
ACELab partner
PostPosted: November 9th, 2014, 13:23
Hi
Look like more like a firmware or weak head problem but require proper diagnose with right tools and knowledge.
Good Luck
Récupération de Données
PostPosted: November 9th, 2014, 14:57
No, it is not a pcb issue because it is correctly recognized.
you should try to image drive e.g ddrescue, atleast only known free option for imaging failing drive.
good luck.
Data Recovery Pakistan
PostPosted: November 9th, 2014, 16:41
Can you retrieve a SMART report with CrystalDiskInfo?
http://crystalmark.info/software/Crysta ... dex-e.html
PostPosted: November 9th, 2014, 17:13
Thanks for your comments.
In fact device is not recognized in USB3 ports, only in USB2 ports.
CrystalMark doesn't start when drive is plugged.
I managed to have a SMART in a linux rescue CD:
Identity : http://i.imgur.com/wKRrvCy.jpg (smart overhall health test PASSED)
Attributes : http://i.imgur.com/1WP3bNj.jpg
Self-test error with read failure: http://i.imgur.com/f1MYGf4.jpg
I'll look into ddrescue.
PostPosted: November 10th, 2014, 11:57
Looks like I may be able to recover data with ddrescue...
http://i.imgur.com/Kbcbf4S.jpg
But it is so slooowww, I didn't find a way to speed up ddrescue, data copy doesn't work with cluster-size superior to 252 (default is 128).
PostPosted: November 10th, 2014, 15:45
Hi mad
let's update with u if you can solve the problem
thanks
PostPosted: November 10th, 2014, 20:43
Only times I've experienced ddrescue to be slow was when I used a flaky USB-cable to the cradle.
PostPosted: November 11th, 2014, 7:24
Thank you very much MindMergepk, ddrescue was the solution !
I perfectly recovered all of my disk, only lost 26MB over 500MB in bad sectors.
ntfsfix fixed the recovered partition boot sector and I was able to mount it perfectly afterward !
Thank you again :)
Users browsing this forum: Google [Bot] and 282 guests
