 Post subject: WD PCB damaged
PostPosted: April 6th, 2015, 9:59
Hi
PCB of this hdd damaged and BIOS integrated.
I replace PCB with PCB same part number but can not solve problem.
what can I do?
Thank you.
image-4632dc687ccd9d82d9f5f3f8e91cdc8e625382fc33e44faf8106b10e1b42b4a1-V.jpg [ 248.08 KiB | Viewed 5795 times ]
Phoenix Computer Forensic Laboratory
http://www.databack.ir
 Post subject: Re: WD PCB damaged
PostPosted: April 6th, 2015, 10:15
what tools you have ?
can you access SA with new pcb ?
ROM can be rebuild from SA.
RAID/Server Recovery
PostPosted: April 6th, 2015, 11:34
If you have access to a PC-3000 you have two options.
1. Read the ROM via the Boot ROM Code utility (often works even for damaged PCBs)
2. Rebuild ROM from SA
PostPosted: April 6th, 2015, 15:31
Thanks all for answers.
I have MRT pro and will do your guide.
Users browsing this forum: No registered users and 38 guests
