 Post subject: St momentus thin.
PostPosted: July 9th, 2015, 10:33
Seagate 320gb thin drive imaging until 17 % then all sectors (unc).
Incomplete translation?
Any thoughts friends?
Thanks in advance.
 Post subject: Re: St momentus thin.
PostPosted: July 9th, 2015, 11:22
Looks lime partial data access.
Sistrum Data Recovery
http://www.sistrum.mk/en
PostPosted: July 9th, 2015, 14:12
Yes.
Until sector 87,000,000 then all sectors UNC
PostPosted: July 9th, 2015, 16:37
Search for fork metod here on the forum or on ACE forum.
PostPosted: July 9th, 2015, 17:16
Try regenerate translator, then try rebuild translator. Just be patient, the forking takes a while.
PostPosted: July 15th, 2015, 10:15
Do you still have original SA backup? Original NRG list ? Issues like this arise from the translator regeneration without taking NRG into account.
PostPosted: July 15th, 2015, 14:11
The drive came to me at this state I didn't do anything yet.
Yes I can access SA and take backup.
Any ideas ?
PostPosted: July 17th, 2015, 9:24
I am totally confused with translator - 1) Regeneration 2) Rebuild.
In which circumstance to use both & difference between them and on which drive families.Can someone pls. guide.
PostPosted: July 17th, 2015, 15:54
basically the rebuild should not be used if regeneration is done properly. Also, fw backup is another thing to avoid rebuild.
Of course, once some smartass tried rebuilding, it is a huge mess and hard to recover.
PostPosted: July 20th, 2015, 16:01
Kiran ,
Its Good To See you Participating Here in The Forums .Keep it Up My Pc 3000 UDMA Should Be With Me In 15 Days To 1 Months Time Frame :D
Users browsing this forum: Google [Bot] and 58 guests
