 Post subject: ST3000DM001 BSY and no Terminal access
PostPosted: August 14th, 2015, 15:18
I have a Seagate ST3000DM001 HDD that spin correctly reaches readiness but doesn't read Drive ID/Capacity...
I could access terminal and test heads ans SMART and everything seems OK.
I had the same problem that I resolved by the F3 T>m0,6,3,,,,,22 command in terminal.
When I tried this command in Terminal, it shows me Partition formatting OK but when I powred ON/OFF the drive, the drive stuck in BSY and when I try to access Terminal it can't and shows me "Terminal : reply timeout error"
I tired to short-cut the read channel, the drive produce a BEEP and stop spinning but steel I can't access Terminal.
Could you please help.
 Post subject: Re: ST3000DM001 BSY and no Terminal access
PostPosted: August 15th, 2015, 3:13
Another DM,
can you upload the terminal output here ?
RAID/Server Recovery
PostPosted: August 15th, 2015, 10:46
Hi
Thank you for your reply.
I tried several times to shortcut the read channel until I got this:
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
FAIL Servo Op=0095 Resp=0003
0095 70D8 0003 7FFF 7FFF 7FFF 0000 0003 0000 0A05 43E8 0004 FFFF 1310 0000 0000 005E 0000 0000 0000 0000 50C0 5639 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 0000 0040 0000 0000 0004 14B0 ED20 DD43 0003 0000 0000 0000 0000 0000 1000 0000 4428 6DFB 4C19 C3E8 F38C AFD5 8049 B656 70A6 93AE 0001 204E 0000 0001 001F 0000 004F
FAIL Servo Op=000E Resp=000B
000E 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 0000 E270 F1FF D7FF F9FF F6FF DFFF EFFF 0000 0000 0000 0000 0000 0000 0000 0000 4428 6DFB 4C19 C3E8 F38C AFD5 8049 B656 70A6 93AE 0001 204E 0000 0001 001F 0000 0000
ResponseFrame 7276 0001 F1FF D7FF F9FF F6FF DFFF EFFF 0000 0000 0000 0000 0000 0000 0000 0000 4428 6DFB FFFF 2000 DFD7 0001 0004 A208 0004 A208 0001 204E 0000 0001 001F 0000 0032
FAIL Servo Op=0100 Resp=0003
0100 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 2200 0056 03B4 3980 0008 891D 0000 FE02 0F3C 0011 0000 0000 0000 0000 0000 0000 4428 6DFB FFFF 2000 DFD7 0001 0004 A208 0004 A208 0001 007F 0004 0001 001E 0004 204E
RECOV Servo Op=0095 Resp=0005
ResponseFrame 0000 0000 0000 0000 0008 891D 0000 FE02 0F3C 0011 0000 0000 0000 0000 1000 0000 4428 6DFB FFFF 2000 DFD7 0001 0004 A208 0004 A208 0001 007F 0004 0001 001E 0004 0016
ResponseFrame 7276 0001 0000 0000 0008 891D 0000 FE02 0F3C 0011 0000 0000 0000 0000 1000 0000 4428 6DFB FFFF 2000 1F71 0001 0004 A208 0004 A208 0001 007F 0004 0001 001E 0004 0032
ResponseFrame 7276 0001 0000 0000 0008 891D 0000 FE02 0F3C 0011 0000 0000 0000 0000 1000 0000 4428 6DFB FFFF 2000 1F71 0001 0004 A208 0004 A208 0001 007F 0004 0001 001E 0004 2032
RECOV Servo Op=0195 Resp=0005
ResponseFrame 0000 0000 0000 0000 0008 891D 0000 FE02 0F3C 0011 0000 0000 0000 0000 1790 0000 4428 6DFB FFFF 2000 DFD7 0001 0004 A208 0004 A208 0001 007F 0004 0001 001E 0004 0016
ResponseFrame 0000 0000 0000 0000 0008 891D 0000 FE02 0F3C 0011 0000 0000 0000 0000 1AAA 0000 4428 6DFB FFFF 2000 DFD7 0001 0004 A208 0004 A208 0001 007F 0004 0001 001E 0004 0016
(DOS) Table Read FAIL
DOS: MAGIC CONFIG NUMBER MISMATCH
(DOS) File Save
RECOV Servo Op=00A5 Resp=0005
(DOS) File Save
ASCII Diag mode
F3 T>
MCMainPOR: Start:
User Data Base 009A8F58
Check MCMT Version: Factory Init
MCInitialize: Start: Host VBM Size (Bytes): 00000210 Metadata VBM Size (Bytes):
ClearMC: Start Full Starting LBA 00015BA8, Count 009899B0
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
F3 T>
RECOV Servo Op=00A5 Resp=0005S22(01)
F3 T>
FAIL Servo Op=008F Resp=0003
008F 0500 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 6704 0001 FFFF 4150 0B61 0561 FE61 0B61 0000 0000 0000 0000 0000 0000 1AAA 0000 4428 6DFB FFFF 2000 DFD7 0001 0004 A208 0004 A208 0001 1005 0000 0000 001E 0000 0000
F3 T>
F3 T>
RECOV Ser
F3 T>
ResponseFrame 7276 0001 FFFF 4262 0B61 0561 FE61 0B61 0000 0000 0000 0000 0000 0000 1AAA 0000 4428 6DFB FFFF 2000 DFD7 0001 0004 A208 0004 A208 0001 1007 0000 0000 001E 0000 0000
F3 T>
F3 T>
The drive doesn't stop spinning and when I ckick on CTRL+Z, I get lines like:
F3 T>00000028qv00000028qv00000028qv00000028qv00000028qv00000028qv00000028qv00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV
F3 T>00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000008qV00000008qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV
F3 T>00000028qV00000028qV00000028qV00000008qV00000008qV00000028qV00000028qV00000028qV00000008qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV
F3 T>00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000008qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000008qV00000028qV00000028qV
F3 T>00000028qV00000008qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000008qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV00000028qV
Then I got:
F3 T>00000028qV00000008qV00000028qV00000028qV00000028qV00000028q[0000000000002B75]v00000028qv00000028qv00000028qv00000028qv00000028qv00000028qv00000028qv00000028qv00000028q
LPC Disc Xfr: EXCEPTION: ProcessRWError: Status =00000002
Next Accessed LBA = 00002B75
Retry LBA = 00002B75
Retry Level = 00000000
Starting LBA of RW Request=0000002B75 Length=00131336
ProcessRWError -Write- at LBA 0000002B75 Sense Code=C4090081
ResponseFrame 6704 0001 0000 0000 0973 1073 1072 0972 0000 0000 0000 0000 0000 0000 1AAA 0000 4428 6DFB FFFF 2000 DFD7 0001 0004 A208 0004 A208 0001 1007 0001 0000 001E 0000 0000
ResponseFrame 7276 0001 FFFF 3E04 0973 1073 1072 0972 0000 0000 0000 0000 0000 0000 1AAA 0000 4428 6DFB FFFF 2000 DFD7 0001 0004 A208 0004 A208 0001 1007 0001 0000 001E 0000 0000
F3 T>
F3 T>
008F 0500 000
ResponseFrame 6704 0001 0000 0000 2005 E1B5 1F97 0972 0000 0000 0000 0000 0000 0000 1A27 0000 4428 6DFB FFFF 2000 DFD7 0001 0004 A208 0004 A208 0000 1007 0000 0000 001E 0000 0000
F3 T>
ResponseFrame 0000 0000 FFFF DA23 2005 E1B5 1F97 0972 0000 0000 0000 0000 0000 0000 1A27 0000 4428 6DFB FFFF 2000 DFD7 0001 0004 A208 0004 A208 0000 1007 0000 0000 001E 0000 FFFF
F3 T>
F3 T>[000000002BBDA43B]v00000028qv00000028qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
FAIL Servo O
p=008F Resp=0003
F3 T>
ResponseFrame 0000 0000 FFFF DA10 2005 E1B5 1F97 0972 0000 0000 0000 0000 0000 0000 1A27 0000 4428 6DFB FFFF 2000 DFD7 0001 0004 A208 0004 A208 0000 1007 0000 0000 001E 0000 FFFF
FAILED to spare00000903
Device Fault is set!
Now I see periodically:
LED:000000BD FAddr:00007C1D
I powered the drive OFF/ON and trying to access Terminal by CTRL+Z, I got:
F3 T>
Update Capacity and Save
(P) SATA Reset
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
Retry delay
MCMainPOR: Start:
ClearMC: Start Full Starting LBA 00015BA8, Count 009899B0S21(01)S21(01)S21(01)S21(01)S21(02)S22(01)S21(01)S21(01)S21(01)S21(01)S21(01)S21(01)S21(01)S21(01)S21(01).
ClearMC: Completed, Last LBA 000099F558
MCInitialize: MC Cleared
MCInitialize: MCTBufferPtr->Header.MCTStateFlags = 0000000A
MCInitialize: MCTBufferPtr->Header.MCStateFlagsDisc = 00000001
MCInitialize: MCStateFlags = 00000001
Set MCMT Version Current
[MCMTWS] Tail/Head 0000 0000
MCInitialize: Init complete:
MCMainPOR: MCTStateFlags 00000022 MCStateFlags 00000040 Tms 00000000 00000000 0000773A PASS
No HOST FIS-ReadyStatusFlags 0002A1A1
Any possible solution without changing heads?
PostPosted: August 15th, 2015, 12:29
Then I tried to short-cut the read channel and I got:
Drive continue spinning, reaches readiness, drive ID read but with wrong capacity?, no terminal access:
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005[LBA=0x000042F9]N02020C
RECOV Servo Op=0095 Resp=000520o0o0o0o0o0o0o0o0
RECOV Servo Op=0095 Resp=0005[LBA=0x000042F9]NO1111[LBA=0x00066E3B]N02020C20o
RECOV Servo Op=0195 Resp=00050o0o0o0o
RECOV Servo Op=0195 Resp=00050o0o0o0[LBA=0x00066E3B]NO1
RECOV Servo Op=0195 Resp=0005111[LBA=0x00028F1D]N02020C20o
RECOV Servo Op=0095 Resp=00050o0o0o0o
RECOV Servo Op=0095 Resp=00050o0o0[LBA=0x00028F1D]NO1111[LBA=0x0008BA5F]N02020C20o0o0o0o0o
RECOV Servo Op=0195 Resp=00050o0[LBA=0x0008BA5F]NO1
SimError - Remaining in BootFW
Perform a double download without a power cycle
See Photo attached:
Then I could re-access Terminal:
MCMainPOR: MCTStateFlags 00000022 MCStateFlags 00000040 Tms 00000000 00000000 000072BC PASS
ASCII Diag mode
F3 T>
F3 T>
F3 T>
I followed the solution for "No HOST FIS-ReadyStatusFlags 0002A1A1" on PC3000 blog: http://blog.acelaboratory.com/pc-3000-h ... error.html
but unfortunately, in the end the drive reaches rediness and I can access Terminal but doesn't read drive ID :roll:
Any help please?
PostPosted: August 15th, 2015, 12:36
The issue was RESOLVED and I could read drive ID and access DATA.
I just closed the utility and re-opened it :D
HTH.
PostPosted: August 15th, 2015, 12:44
glad you have solve this.
did you clear only s.m.a.r.t, power cycle hard drive and re-enter utility ?
PostPosted: August 16th, 2015, 3:05
No, I just short-cut the read channel several time to get access the Terminal, then I followed the guide on http://blog.acelaboratory.com/pc-3000-h ... error.html
HTH
PostPosted: August 16th, 2015, 3:56
thanks for sharing.
PostPosted: August 17th, 2015, 4:13
HTH
Congratulations to solve this and got the data :)
But, Can you show to me how do short-cut the read channel by image to be more clarify for me.
Expect, the Unexpected
PostPosted: August 18th, 2015, 10:03
Follow this steps:
PostPosted: August 20th, 2015, 1:34
thank you sosrecup for clarify,
Users browsing this forum: No registered users and 87 guests
