 Post subject: Strange Case: Changes stop to have effect after power OFF
PostPosted: October 15th, 2015, 10:53
Hi friends:
I am dealing with a Seagate ST380811AS. The hdd has a few bad sectors but any intent to repair it becomes unsuccessful because hdd always returns to its original state after power cycle. Tried different bad sector repair softwares like Seatools, MHDD, Hdat and terminal commands, also tried zero fill, low level format, cut HPA, clear smart and Glist, selfscan commands and seemingly all finish without error, but after power off/on the files, folders and bad sectors remains intact.
Any idea?
thanks in advance,
Oleg.
 Post subject: Re: Strange Case: Changes stop to have effect after power OF
PostPosted: October 15th, 2015, 12:35
What is you goal here - repair the drive or recover data ?
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: October 15th, 2015, 13:12
Writing doesn't work. If you are looking to repair drive - you need to solder terminal adapter for seagate. There is no other way to repair drive. You could come again with initial terminal outputs and we can continue to try to repair drive.
PostPosted: October 17th, 2015, 14:25
digisupport: Data is not important, already saved it.
drHDD: I dont understand what you want to say with "you need to solder terminal adapter for seagate". I have a USB TTL adpater for serial port connection, i imagine that you refers to it. I tried via terminal commands, cleared smart y glist, tried low level format with command T48 and all commands gave no error but after power off hdd remains like before.
Spildit: I have not firmware tools, but i can asume the selfscan (N10,,22) risk if is not mandatory backup fw modules. It is required or mandatory to restore the fw modules or there is a chance that it work without this?
PostPosted: October 24th, 2015, 15:45
Well tried some commands an also Selfscan command and stops after Test 00. It was curious that the only way to start selfscan was restarting hdd in slip mode (CTRL+T), because with power off after N10,,22 command was ignored.
Here is the log.
T>Interface task reset
4096k x 16 SDRAM
TONKA2 - 1_Disk M-31 02-07-06 16:50
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
(P)SATA Reset
T>N10,,22 (AND PRESSED CTRL+T)
T>
************* Cert Log Cyls inadequate. 0006 more cyls required
Cert Table loaded
Begin Test 10
ASCII logging on
ASCII logging off
ASCII logging on
Temp Diode 007B Not Power Cycling
( 38 C )
Cert Temp = ( 38 C )
Zone F
EP=0, TA=0, HiGain=0, OTRd=0, Early Rd=0, Splash=0, Reload=0, NPML=0, MRBias=0
Bst/Zap=0, SrvoThrsh=0, RunOut=0, MaxECC=0, ECC 2=0, ECC 1=0, ECC 0=1
Data=01, Write=40, ID=FF, DER=0000, RdWrOpts=0001
Adapt Data Zone 0f
Test 000211af.00 0002e4cd BER 0000001a
Map 000211af.00 Trk Skipped 211af.0
Defects 0000
Test 000211af.00 0002dc8b BER 0000001a
Adapt Data 000211af.00
Rbck DATA load
NPML 00
Test 000211af.00 00012237 BER 0000001b
Adjust ATTR 02 VGAS 8b VGAR 82 FREQR 84 within _ATT VGAR FREQR
MRASYM 79 00012307 BER 00000025
MRASYM 77 00011b53 BER 00000019 update 77 hold
Test 00021110.00 0001202f BER 00000026
Servo Zone 1F OD OFST Lower 061b Upper 06da Step 0006 Right 1f Mask 00004340
Default 067b 00011c1c BER 00000024
Floor 1 1b 000297ef 000297ef
Left 1 0645 000273d0
Middle 1 067a 00011da2
Right 1 06b0 000235e4
Lowest 1 067b 000116fe
Z = -A1/(2*A2) : 0000
X = Z + Xavg : 000F
Curve 0675 00011da2
New 067a 00011d40 BER 00000017
Test 00021dbf.00 0001428b BER 0000003e
Servo Zone 1F ID OFST Lower 06d5 Upper 0794 Step 0006 Right 1f Mask 00008340
Default 0735 00014324 BER 00000033
Floor 1 1a 0002b561 0002b561
Left 1 070b 00025dc0
Middle 1 073d 00013f25
Right 1 0770 0002a0d5
Lowest 1 073b 00013f25
X = Z + Xavg : 000F
Curve 072f 00014dcf
New 073d 00014233 BER 0000003a AUTO
Adjust ATTR 02 VGAS 8a VGAR 83 FREQR 83 within _ATT VGAR FREQR
Test 000211af.00 00012019 BER 00000012
Noise target 00000000
Rbck Noise OFF
Rbck DATA save
Test 000211af.00 00011fc5 BER 00000022
MRASYM 77 000122d8 BER 00000021
MRASYM 72 00011d7d BER 0000001a update 72 hold
PRECOMP Lower 0000 Upper 000a Step 0001 Right 0a Mask 00000004
Default 0005 0001213f BER 0000001c
Floor 1 0b 000120dd 00012175
Left 1 0000 000120dd
Middle 1 0003 0001213d
Right 1 0006 00011fe2
Lowest 1 0002 00011e70
Z = -A1/(2*A2) : FFFF
X = Z + Xavg : 0004
Curve 0004 000121e0
New 0003 000121d3 BER 00000024
Test 000211af.00 000122e1 BER 0000002b
XDCTAP 6b 00011ed2 BER 00000022 adapt
XDCTAP 6f 00011b56 BER 0000001b hold
CUTOFF Lower 0416 Upper 043a Step 0002 Right 12 Mask 00000348
Default 0432 00066855 BER 00000003
Floor 1 0d 00067263 0006de2f
Left 1 0428 00066d0e
Middle 1 0430 00065fb6
Right 1 043a 00066710
Lowest 1 042a 000652d7
New 0430 00065463 BER 00000007 AUTO
BOOST Lower 0000 Upper 0016 Step 0001 Right 16 Mask 00000360
Default 0015 00065c1e BER 00000002
Floor 1 17 00065da8 00082e71
Left 1 0016 00065da8
Middle 1 0016 00065da8
Right 1 0016 00065da8
Lowest 1 0016 00065da8
Z = -A1/(2*A2) : FFED
X = Z + Xavg : FFF8
Curve 0015 00065e25
New 0016 00065dbd BER 00000002
TAPDELT Lower 0004 Upper 000d Step 0001 Right 09 Mask 00000350
Default 0005 00066c19 BER 00000004
Floor 1 0a 00067745 0006e450
Left 1 0004 00067745
Middle 1 0005 00066ba9
Right 1 0006 00066f70
Lowest 1 0005 00066ba9
Z = -A1/(2*A2) : 0003
X = Z + Xavg : 0007
Curve 000b 00071e1c
New 0005 000661df BER 00000002 AUTO
Servo Zone 1F OD OFST Lower 061a Upper 06d9 Step 0006 Right 1f Mask 00004340
Default 067a 00011890 BER 00000028
Floor 1 1b 00027680 00027680
Left 1 064a 000229a3
Middle 1 067c 000118ec
Right 1 06af 00021fb5
Lowest 1 0680 00011711
X = Z + Xavg : 000F
Curve 0674 00011b0b
New 067c 000114b8 BER 00000015 AUTO
Servo Zone 1F ID OFST Lower 06dd Upper 079c Step 0006 Right 1f Mask 00008340
Default 073d 00013ebd BER 00000038
Floor 1 18 00026927 00026927
Left 1 070d 00023727
Middle 1 073c 00014454
Right 1 076c 00024b8a
Lowest 1 073d 00014151
X = Z + Xavg : 000F
Curve 0737 00014454
New 073c 000140d7 BER 00000039
CUTOFF Lower 0428 Upper 043a Step 0001 Right 12 Mask 00000348
Default 0430 000655aa BER 00000000
Floor 1 06 00065720 000660a8
Left 1 042d 00065136
Middle 1 042e 00065174
Right 1 0430 00065241
Lowest 1 042d 00065136
New 042e 00066287 BER 00000002
BOOST Lower 0015 Upper 0016 Step 0001 Right 01 Mask 00000360
Default 0016 0006641d BER 00000000
Floor 1 02 00065678 000659f6
Left 1 0016 00065678
Middle 1 0016 00065678
Right 1 0016 00065678
Lowest 1 0016 00065678
Not Enough Points to Curve Fit!
New 0016 0006706c BER 00000004
Default 0005 00064fb0 BER 00000005
Floor 1 0a 00067118 0006e6bc
Left 1 0004 00067118
Middle 1 0004 00067118
Right 1 0005 00065488
Lowest 1 0005 00065488
Z = -A1/(2*A2) : 0001
X = Z + Xavg : 0005
Curve 0009 00075570
New 0004 000689f5 BER 00000003
Rbck Noise OFF
Adjust ATTR 02 VGAS 89 VGAR 7c FREQR 83 within _ATT VGAR FREQR
MRASYM 72 000135b5 BER 0000001c
MRASYM 73 00012cdf BER 00000037 update 73 adapt
Test 000211af.00 0001301d BER 00000024
MRASYM 73 00012f70 BER 0000001e
MRASYM 76 0001318e BER 00000021 hold
NPML 03 00012d68 BER 00000021 NPML update
NPML 03 0002b56c BER 00000024
MRASYM 73 0002bb28 BER 0000001a
MRASYM 71 0002bca8 BER 00000025 adapt
UPDATE TAPS Rbck DATA save
Media 0000
[00021110,0,061C,06DC, 1, 2] ->Min=000B(0674) BL=065A BR=069E Range=0045 Pick=06
7C
[00021114,0,061C,06DC, 1, 2] ->Min=000F(067C) BL=0660 BR=069A Range=003B Pick=06
7D
[00021118,0,061C,06DC, 1, 2] ->Min=000F(0684) BL=0652 BR=0694 Range=0043 Pick=06
73
[0002111C,0,061C,06DC, 1, 2] ->Min=000E(0680) BL=065A BR=069C Range=0043 Pick=06
7B
[00021120,0,061C,06DC, 1, 2] ->Min=0011(0682) BL=0660 BR=069E Range=003F Pick=06
7F
[00021124,0,061C,06DC, 1, 2] ->Min=000D(067C) BL=0656 BR=06A2 Range=004D Pick=06
7C
Average MR Offset is 067B
[00021DAF,0,06DC,079C, 1, 2] ->Min=0014(0738) BL=0718 BR=0752 Range=003B Pick=07
35
[00021DB3,0,06DC,079C, 1, 2] ->Min=001E(0738) BL=0724 BR=0754 Range=0031 Pick=07
3C
[00021DB7,0,06DC,079C, 1, 2] ->Min=0018(073A) BL=071E BR=074A Range=002D Pick=07
34
[00021DBB,0,06DC,079C, 1, 2] ->Min=0018(073E) BL=0720 BR=075A Range=003B Pick=07
3D
[00021DBF,0,06DC,079C, 1, 2] ->Min=0020(0738) BL=0720 BR=074C Range=002D Pick=07
36
[00021DC3,0,06DC,079C, 1, 2] ->Min=0023(0730) BL=0718 BR=0748 Range=0031 Pick=07
30
Average MR Offset is 0736
ASCII logging off Power Cycling
************* ASCII LOG OVERFLOW ****************
Test=50, Feature=0, cumhlth=0008, curhlth=0000
OkEnd Test 00
At this point selfscan test stops. The age not changed, was mantained at 50.
T>Age=50 Type=3F MxCyl=21DC7 MxHd=0 MxSct=008 BSz=008M TCode=02000000 ThermFlts=
0000
Inspected logs if any error, but nothin.
T>(VALID Cert Disk Code Detected - Revision # .0B8
T>E4E
og 4E - Health 0008 - HlthDtl 0000 - Cert Rev = .0C5 - Rom Rev = 3.AA.0F6 - Time
= 00:00:12 Log Type = 01
Log 02 - Health 0000 - HlthDtl 0000 - Time = 00:26:32 Log Type = 01
Log 83 - Health 0000 - HlthDtl 0000 - Time = 00:01:31 Log Type = 01
Log 84 - Health 0000 - HlthDtl 0000 - Time = 00:00:09 Log Type = 01
Log 03 - Health 0000 - HlthDtl 0000 - Time = 00:05:18 Log Type = 01
Log 06 - Health 0000 - HlthDtl 0000 - Time = 00:00:01 Log Type = 01
Log 07 - Health 0000 - HlthDtl 0000 - Time = 00:00:09 Log Type = 01
Log 90 - Health 0000 - HlthDtl 0000 - Time = 00:02:21 Log Type = 01
Log 93 - Health 0000 - HlthDtl 0000 - Time = 00:02:24 Log Type = 01
Log 98 - Health 0000 - HlthDtl 0000 - Time = 00:02:22 Log Type = 01
Log 9C - Health 0000 - HlthDtl 0000 - Time = 00:02:26 Log Type = 01
Log AA - Health 0000 - HlthDtl 0000 - Time = 00:03:53 Log Type = 01
Log 81 - Health 0008 - HlthDtl 0000 - Time = 00:12:52 Log Type = 01
Log 09 - Health 0000 - HlthDtl 0000 - Time = 00:14:25 Log Type = 01
Log 74 - Health 0000 - HlthDtl 0000 - Time = 00:06:06 Log Type = 01
Log E3 - Health 0000 - HlthDtl 0000 - Time = 00:06:04 Log Type = 01
Log 0F - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 01
Log 82 - Health 0008 - HlthDtl 0000 - Time = 00:00:35 Log Type = 01
Log 94 - Health 0000 - HlthDtl 0000 - Time = 00:00:21 Log Type = 01
Log 56 - Health 0000 - HlthDtl 0000 - Time = 00:01:26 Log Type = 01
Log 99 - Health 0000 - HlthDtl 0000 - Time = 00:00:01 Log Type = 01
Log 10 - Health 0000 - HlthDtl 0000 - Time = 00:02:21 Log Type = 01
Log 11 - Health 0000 - HlthDtl 0000 - Time = 00:02:20 Log Type = 01
Log 12 - Health 0000 - HlthDtl 0000 - Time = 00:01:38 Log Type = 01
Log 13 - Health 0000 - HlthDtl 0000 - Time = 00:02:25 Log Type = 01
Log 14 - Health 0000 - HlthDtl 0000 - Time = 00:02:23 Log Type = 01
Log 15 - Health 0000 - HlthDtl 0000 - Time = 00:02:24 Log Type = 01
Log 16 - Health 0000 - HlthDtl 0000 - Time = 00:02:24 Log Type = 01
Log 17 - Health 0000 - HlthDtl 0000 - Time = 00:02:25 Log Type = 01
Log 18 - Health 0000 - HlthDtl 0000 - Time = 00:01:38 Log Type = 01
Log 19 - Health 0000 - HlthDtl 0000 - Time = 00:02:24 Log Type = 01
Log 1A - Health 0000 - HlthDtl 0000 - Time = 00:02:26 Log Type = 01
Log 1B - Health 0000 - HlthDtl 0000 - Time = 00:03:10 Log Type = 01
Log 1C - Health 0000 - HlthDtl 0000 - Time = 00:02:26 Log Type = 01
Log 1D - Health 0000 - HlthDtl 0000 - Time = 00:03:05 Log Type = 01
Log 1E - Health 0000 - HlthDtl 0000 - Time = 00:02:17 Log Type = 01
Log 2A - Health 0000 - HlthDtl 0000 - Time = 00:03:04 Log Type = 01
Log DA - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 01
Log DC - Health 0000 - HlthDtl 0000 - Time = 00:00:03 Log Type = 01
Log D6 - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 01
Log D7 - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 01
Log D8 - Health 0000 - HlthDtl 0000 - Time = 00:00:04 Log Type = 01
Log D9 - Health 0000 - HlthDtl 0000 - Time = 00:00:03 Log Type = 01
Log 7C - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 01
Log B9 - Health 0000 - HlthDtl 0000 - Time = 00:00:23 Log Type = 01
Log 7D - Health 0000 - HlthDtl 0000 - Time = 00:00:49 Log Type = 01
Log 78 - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 01
Log 58 - Health 0000 - HlthDtl 0000 - Time = 00:02:53 Log Type = 01
Log 23 - Health 0000 - HlthDtl 0000 - Time = 00:04:11 Log Type = 01
Log 8F - Health 0000 - HlthDtl 0000 - Time = 00:02:26 Log Type = 01
Log 40 - Health 0000 - HlthDtl 0000 - Time = 00:24:49 Log Type = 01
Log 47 - Health 0000 - HlthDtl 0000 - Time = 00:00:58 Log Type = 01
Log 31 - Health 0000 - HlthDtl 0000 - Time = 04:23:15 Log Type = 02
Log AB - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 01
Log 32 - Health 0000 - HlthDtl 0000 - Time = 00:00:01 Log Type = 02
Log 33 - Health 0000 - HlthDtl 0000 - Time = 00:00:01 Log Type = 02
Log 34 - Health 0000 - HlthDtl 0000 - Time = 00:00:01 Log Type = 02
Log A5 - Health 0000 - HlthDtl 0000 - Time = 00:00:01 Log Type = 02
Log A6 - Health 0000 - HlthDtl 0000 - Time = 00:00:01 Log Type = 02
Log 36 - Health 0000 - HlthDtl 0000 - Time = 00:00:14 Log Type = 02
Log A8 - Health 0000 - HlthDtl 0000 - Time = 00:00:06 Log Type = 02
Log 37 - Health 0000 - HlthDtl 0000 - Time = 00:02:32 Log Type = 02
Log 3A - Health 0000 - HlthDtl 0000 - Time = 01:11:34 Log Type = 02
Log 8A - Health 0000 - HlthDtl 0000 - Time = 00:04:46 Log Type = 01
Log 3B - Health 0000 - HlthDtl 0000 - Time = 00:00:43 Log Type = 02
Log 3C - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 02
Log 3D - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 02
Log 3E - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 02
Log A9 - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 01
Log 3F - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 01
Log 20 - Health 0000 - HlthDtl 0000 - Time = 00:14:25 Log Type = 01
Log 77 - Health 0000 - HlthDtl 0000 - Time = 00:00:38 Log Type = 01
Log 9D - Health 0000 - HlthDtl 0000 - Time = 00:00:13 Log Type = 01
Log E0 - Health 0000 - HlthDtl 0000 - Time = 00:07:57 Log Type = 01
Log 87 - Health 0000 - HlthDtl 0000 - Time = 00:07:29 Log Type = 01
Log 88 - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 01
Log 41 - Health 0000 - HlthDtl 0000 - Time = 00:02:19 Log Type = 01
Log 4B - Health 0000 - HlthDtl 0000 - Time = 00:01:24 Log Type = 01
Log 44 - Health 0000 - HlthDtl 0000 - Time = 00:03:33 Log Type = 01
Log 48 - Health 0000 - HlthDtl 0000 - Time = 00:47:43 Log Type = 01
Log 49 - Health 0000 - HlthDtl 0000 - Time = 00:23:12 Log Type = 01
Log 53 - Health 0000 - HlthDtl 0000 - Time = 00:06:44 Log Type = 01
Log 4A - Health 0000 - HlthDtl 0000 - Time = 00:00:09 Log Type = 01
Log 4D - Health 0000 - HlthDtl 0000 - Time = 00:00:22 Log Type = 01
Log 8B - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 01
Log 61 - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 01
Log 28 - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 01
Log 62 - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 01
Log 29 - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 01
Log 63 - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 01
Log 59 - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 01
Log 85 - Health 0000 - HlthDtl 0000 - Time = 00:00:12 Log Type = 01
Log 35 - Health 0000 - HlthDtl 0000 - Time = 00:01:25 Log Type = 01
Log 6F - Health 0000 - HlthDtl 0000 - Time = 00:00:57 Log Type = 01
Total Cert Time = 10:32:58
T>T4
Begin Test 04
ASCII logging on
ASCII logging off
ASCII logging on
Kick Off Test
Testing head 0...
DAC value = FC85
Biasing with current 0025mA
DAC value = FAC5
Biasing with current 0050mA
DAC value = F90D
Biasing with current 0075mA
DAC value = F754
Biasing with current 0100mA
DAC value = F58E
Biasing with current 0125mA
DAC value = F3D6
Biasing with current 0150mA
DAC value = F219
Biasing with current 0175mA
DAC value = F05A
Biasing with current 0200mA
DAC value = FC82
Passed Max OD Bias Current = 0200mA. Limit = 0100mA
Spin Ready
ASCII logging off
OkEnd Test 00
Any idea?
Users browsing this forum: Google [Bot], mima85 and 48 guests
