 Post subject: Seagate - ROM Physical Damage [ Ground Leg No 4 ]
PostPosted: October 29th, 2015, 14:33
Hello ,
One Of My DR Recovery Colleagues In India Has Send Me One Case .The PCB Was Horrible Handled And I Am Now Stuck At One Place [ ROM Leg No 6 Just Comes Out ] . If No Ground No Data From IC .What Are My Chances Here .
Will This Work Or I Am Wasting My Time ...
1 :Get a Xray Done Of The Chip [ Can Someone Suggest What Kind Of Xray Would Be OK ]
2 : If i Do See a Small Wireline Trace i Dig Upto It And Test My Soldering Skill [ Not Bad At It Though ]
3 : Try Reading If Done Great Otherwise No Point .
Suggestions Please ...
 Post subject: Re: Seagate - ROM Physical Damage [ Ground Leg No 4 ]
PostPosted: October 29th, 2015, 15:46
Sometimes you can just wedge a sharp pair of tweezers in there and make the connection long enough to read it. I know it's worked for me on occasion.
PostPosted: October 30th, 2015, 1:14
Brilliant Idea Jared ,
But Like This We Could Push The Wire Back .Haque ,Jermyb,Arvika Guys You Are The NAND Experts and might be getting Xray done ,Please Help
PostPosted: October 30th, 2015, 4:50
It worked for me too on an occasion. :D
My firmware database:
PostPosted: October 30th, 2015, 5:03
Hi Michael ,
Thanks For Double Confirmation .I Am Currently On a Screwed up Samsung PCB And Once That is Over i Will Give This a Try .Few of My Friends At [ Flash Section ] Possibly Have Not Seen The Thread .I Really Wanted Advice of What Kinda Xray To Do With This [ Without Wasting Time And Money ] .
PostPosted: October 30th, 2015, 6:12
I think this photo like u
PostPosted: October 30th, 2015, 6:32
Hello ,
Nothing To Like In This Photo .Pin 4 Is Ground And Already stated
PostPosted: October 30th, 2015, 7:42
you said pin no. 6.
PostPosted: October 30th, 2015, 8:19
jermy wrote:
you said pin no. 6.
Hi Jermy ,
Was a Typo Sorry For That .Any Suggestions For a XRAY ? .
PostPosted: October 30th, 2015, 8:42
i really don't see the point for an X-ray
lets say got an X-RAY what you gonna do next with it ?
take the advice from data-medics and michael chiklis
PostPosted: October 30th, 2015, 8:50
Well,
Rest i Will Handle ,even if i have to dig to that wire manually i will do it
PostPosted: October 30th, 2015, 9:26
Spildit wrote:
What is the model of this Seagate drive ? It's an F3 arch, correct ?
the PCB on pic. seems like an F3, if it wouldn't then what's the big deal
PostPosted: November 4th, 2015, 6:32
Alternatively you can dig and solder a thin flexible wire to it, the way its used for Memory cards.
Generally GND Pin is a thick pin internally in my observation...
PostPosted: November 4th, 2015, 8:06
If you give up send the chip to Denmark i will read it for free - just to prove my concept :)
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: November 5th, 2015, 19:05
It seems to be pharaoh to me. I think the easiest way is to solder thin wires to the chip and read. If it fails, we can recover the data without the original rom from this family.
PostPosted: November 6th, 2015, 1:55
Silver conductive ink can be used to bond the thin strand of wire and make necessary connection , in case you cannot solder.
PostPosted: November 6th, 2015, 4:14
great idea
PostPosted: November 6th, 2015, 6:53
Have done the same in a lot af cases :)
PostPosted: November 12th, 2015, 11:01
Hi Everyone ,
Its Indeed a F3 .Its a pharaoh .When you Guys Says a Thin Wire [ I understand Its a Wire Out From The Dye To The Leg ] .Would This Wire Be visible If We Remove The Leg From The Body under a Scope Or Something .
@ Pepe Sir : These Days 24 Hours i Am Working On DR Sir .If You Would Be Able To Do It i Will Try And Learn To Do It Also .The Engineer In Me Never Gives Up [ Thats The Spirit The Old Man Has ] .
@ digisupport : I Will Definitely Nail This Buddy .Gimme a Day When i Can Work on This Case . Really Appreciate Your Help BTW [ No Pun Intended ]
@ Everyone : Thanks Guys This is The Essense of a Great Forum Keep It Up
Users browsing this forum: Zero Alpha and 42 guests
