 Post subject: WD USB 3 - 750GBHDD
PostPosted: December 9th, 2015, 4:13
Dear Friend'S,
I have a this hard disk.
this hard disk ROM chip burn.
what can do for this for recovery data ?
 Post subject: Re: WD USB 3 - 750GBHDD
PostPosted: December 9th, 2015, 4:17
If you have a matching donor you can try hotswap and/or regen ROM, but you need FW tools like PC3K, MRT, WDMarvel or FRP to do that.
For PC3K take a look here
Best regards,
030 Datenrettung Berlin GmbH (Germany)
HDD, SSD, NAS, RAID Datenrettung - 030-datenrettung.de
PostPosted: December 9th, 2015, 4:21
Thanks for your reply.
i have a MRT Tool.
PostPosted: December 9th, 2015, 4:22
I feel have to ask this.
In your data recovery lab is there anybody who knows how to deal with basic recovery or do you always have to ask on this forum how to do every job? :lol:
PostPosted: December 9th, 2015, 4:25
Hi Yes,
i am new for this data recovery process..
PostPosted: December 9th, 2015, 4:42
damindaniroshana wrote:
Hi Yes,
You seems new to every process...
Don't work on clients drives unless you know what you're doing.
http://www.rescue-it.se
PostPosted: December 9th, 2015, 4:47
:lol:
i know do hot swap process.
more time i do this with SAMSUNG HDD,
first time come to me WD USB 3 HDD with this problem.
PostPosted: December 9th, 2015, 4:50
and this hard disk problem is,
power spin up well, but not detect via USB.
PostPosted: December 9th, 2015, 5:29
If disk spins fine why should ROM be damaged?
Convert drive to SATA and see if you can work on it with MRT to fix FW-issues like slow-init, damaged modules and so on.
+1 Please do not risk clients data, if you do not know how to use MRT yet, do not use it on client drives!
best regards,
PostPosted: December 9th, 2015, 5:36
Then the ROM is fine. Bad diagnosis :-(
PostPosted: December 9th, 2015, 5:57
i do that,
then hard disk motor not spin up.
USB PCB Number - 2060-771737-000, I am replace SATA PCB number is 2060-771692-005. and swap ROM chip.
why then HDD motor not spin up ?
PostPosted: December 9th, 2015, 6:42
because you swapped the wrong chip
PostPosted: December 9th, 2015, 6:55
There Have a 2 Chip U12 & U8.
I am swap U12 Chip.
it's correct ?
PostPosted: December 9th, 2015, 7:13
you swapped its contents or the chip it self ?
PostPosted: December 9th, 2015, 7:17
U12, CHIP.
PostPosted: December 9th, 2015, 8:09
Not spinning: Might be U12 is not correctly soldered. These WSON8 are not as easy to swap as the ones with legs. I would get the chip off and make a ROM backup with external programmer so if it reads ROM should be fine and you have a backup :wink: . Then resolder it on the pcb and try if drive spins.
btw: what happened with U8? Looks also not in place ... if you do clients drive plz stop it.
Best regards,
PostPosted: December 9th, 2015, 8:15
I have a U8 CHIP copy.
PostPosted: December 9th, 2015, 8:20
not important, the more important is the U12
although it can be dealt with (even it's damaged)
PostPosted: December 9th, 2015, 12:23
You need to practice your soldering skills!
U8 is clearly sitting at an angle. The soldering is also untidy.
More importantly U12 is positioned off centre. I would suggest it is so far out of alignment the pins might not make contact with ALL the pads. If that is the case then of course the drive won't spin!
You also need to check your own work!
PostPosted: December 9th, 2015, 13:46
+1 http://prntscr.com/9c7p34
Users browsing this forum: Google [Bot] and 204 guests
