 Post subject: Seagate ST2000DM001. Spins up normally. Not detected in bios
PostPosted: January 11th, 2016, 3:23
Hi all!
A few days ago my harddrive no longer appeared anywhere on windows and is not detectable in the bios either. The specifications are as follows:
Seagate Barracuda 2000GB
SN: W240ARA9
MODEL: ST2000DM001
PN: 9YN164-302
FW: CC4C
DATE: 12357
SITE: SU
Summary of problem:
Drive spins up normally on booting
Drive not recognised by the bios.
Drive is not shown in Windows 7 or in the device list of Ubuntu on multiple computers.
Drive is not seen by MHDD on a bootable usb.
Any help would be greatly appreciated as I am unsure what to proceed with next. I would be willing to pay for a professional to do this however I am in Australia and although the data is worthwhile to me, it probably isn't worth more than a couple hundred dollars, so I wanted to exhaust all other options first.
As has been mentioned on these forums, I have not tried to use a USB connection yet as I am unsure of how to exactly do this and so if someone had a guide to do this procedure that would be lovely. Replacing the PCB board was also mentioned several times however it seemed that was the solution if the HDD didn't spin at all.
Thanks for all your help,
Paul.
 Post subject: Re: Seagate ST2000DM001. Spins up normally. Not detected in
PostPosted: January 11th, 2016, 4:15
contact HaQue he is located in Adelaide
PostPosted: January 11th, 2016, 4:24
Thanks! I don't think I can send private messages yet as my account is new, will he see you have linked his name in this thread?
PostPosted: January 11th, 2016, 4:26
Thanks! I don't think I can send private messages yet as my account is new, will he be notified that you linked his name in this thread?
PostPosted: January 11th, 2016, 4:32
+ 1 Contact HaQue
At this stage recovery chances are high if the drive spins up normally and stays spinning.
I wouldn't recommend any DIY attempts on this model of drive if data is important. They can become very expensive and almost impossible to recover quickly if you start playing around with them.
If it doesn't detect over SATA, then USB won't either.
Won't change anything.
Web: https://www.day1data.de
PostPosted: January 11th, 2016, 5:58
+2 HaQue
PostPosted: January 11th, 2016, 6:01
Thanks everyone! I'm unable to send HaQue a private message due to my account being new, will HaQue see jermy's link of his profile?
PostPosted: January 11th, 2016, 6:14
why not
what difference does it make ?
PostPosted: January 11th, 2016, 10:40
jermy wrote:
why not
I only meant that to question whether he would be notified of this thread, I don't know how active he is in the forums and I'm unable to message him directly.
PostPosted: January 11th, 2016, 16:48
very active ;-)
PM Sent
PostPosted: January 11th, 2016, 19:47
I have the same problem with Seagate ST2000DM001
It spining but not detected by Windows 7
BIOS detect this drive, but when BIOS loading it hold on several seconds and then show hard drive have an error.
Windows 7 don't see this drive at all.
PostPosted: February 6th, 2016, 18:23
HaQue could you PM me as well. I have a similar situation but have been though a pcb and chip swap and a platter transplant by a pro already. I receive the drive back next week and was advised that the drive spins but is not detected by BIOS thus nothing is recoverable. I am looking for some ideas of my next steps. My important data = daughters' baby thru 4 years pictures. I would greatly appreciate any assistance.
PostPosted: February 7th, 2016, 4:11
If it is the same situation (drive was originally spinning but not detected) it's rather worrying that the "pro" performed a platter swap :-(
PostPosted: February 7th, 2016, 8:53
It was a little different. Board received over voltage and blew the board. No spin.
The board was swapped out and chip data transferred with a comprable board via HDD-Parts. No luck. Then, another pcb swap with an exact board and the chip physically transferred. No spin. Then, platter swap. Drive spins now but not recognized by BIOS. I am hoping that slaving the drive and running SeaTools or something else will give me an opportunity to grab jpg data.
Users browsing this forum: No registered users and 37 guests
