 Post subject: WD10JMVW-11AJGS2(USB to SATA) Recovery
PostPosted: February 6th, 2016, 4:51
HDD : WDC WD10JMVW-11AJGS2 WD-WXJ1EA3LZFH5
Type : USB 3.0
PCB : 771961(usb)
Status: Detected by Bios and windows with all partitions and Files
Problem:
Read Very Slow 70KB/S
Steps Taken:
1. PCB 771961(USB) replaced by 771959 (SATA)
2. ROM Chip U12 Transferred
After usb to sata pcb changed, HDD is visible with partitions and files Then tried to apply slow fix
WDR 6.0 Identifies the hdd but can't read any modules
WdMarvel beta 7a and 9 detects the hdd model but can't read any modules
From Log
06-02-2016 08:38:48 AM: The drive WDC WD10JMVW-11AJGS2 Disk size 1953459633 - 1000Gb
06-02-2016 08:39:07 AM: The error in determining the number of heads
06-02-2016 08:39:10 AM: Error reading module Dir, state - 4F10
HDDSupertool 1.6 Log
hddsupertool 1.6-1.5 20160130
Finding devices
Q) Quit
R) Refresh drive list
1) /dev/sda ST31000524AS 9VPGBSEW
2) /dev/sdb WDC WD10JMVW-11AJGS2 WD-WXJ1EA3LZFH5
3) /dev/sdc sense-data 05 20 00
4) /dev/sdd sense-data 05 20 00
5) /dev/sde sense-data 05 20 00
6) /dev/sdf sense-data 05 20 00
7) /dev/sdg sense-data 05 20 00
Choose which drive > 2
Main menu
q) Quit
h) Toggle script help
1) Device information
2) Read sectors
3) Write sectors
4) Erase sectors
5) Tools
6) Security
7) VSC
8) Image device
9) Custom
Enter your choice:
> 7
7
VSC menu
q) Quit
p) Previous menu
1) WD dump mod 42 (older Caviar drives)
2) WD royl (Marvel) dump mod 02
3) WD royl (Marvel) dump mod 32
4) WD royl (Marvel) patch mod 02 (slow fix)
5) WD royl (Marvel) patch mod 32 (slow fix)
6) WD royl (Marvel) dump all modules
Enter your choice:
> 4
4
WD ROYL Patch Mod02
This modifies data in the service area of the drive!
Use at your own risk!
These commands can take several minutes and appear to be hung.
Please be patient and let it finish on its own.
q) Quit
p) Previous menu
1) Read the module to a file and create the patch.
2) Write the patched data back to the disk.
3) Restore the original dump.
Enter your choice:
> 1
1
Performing identify device command
Model: WDC WD10JMVW-11AJGS2
Serial: WD-WXJ1EA3LZFH5
Reading the module
Command failed!
sense_key=0xb asc=0x0 ascq=0x0
error=0x4 count=0x10 lba=0x4f device=0xa0 status=0x51 altstatus=0x0
command_status= 0x0
data_transferred= 0x200
VSC menu
q) Quit
p) Previous menu
Enter your choice:
> 5
5
WD ROYL Patch Mod32
q) Quit
p) Previous menu
Enter your choice:
> 1
1
Reading the module
Command failed!
command_status= 0x0
VSC menu
q) Quit
p) Previous menu
Enter your choice:
> 2
2
Command failed!
command_status= 0x0
VSC menu
q) Quit
p) Previous menu
Enter your choice:
> 3
3
Command failed!
command_status= 0x0
VSC menu
q) Quit
p) Previous menu
Enter your choice:
Pls advice me How to Solve slow fix for this?
 Post subject: Re: WD10JMVW-11AJGS2(USB to SATA) Recovery
PostPosted: February 6th, 2016, 6:02
what happened to disk ?
was it dropped ?
does the sound of drive is absolute normal ?
there is thread where user was successfully able to apply slow-fix by using HDD Super Tool, if it is not working could be head/s.
viewtopic.php?f=1&t=32501&start=20
proper diagnostic is required.
Data Recovery Pakistan
PostPosted: February 6th, 2016, 8:18
1. No strange sound
2. No Delay in detect by bios and windows
3. All Partition and Files are visible both in linux and windows
the only actual problem is slow slow ... slow reading at ~70K/s in both USB(1961) and SATA(1959)
PostPosted: February 6th, 2016, 8:28
Start with copying the most important data at this state then try to fix it later or send it to a DR company with proper tools to fix it for a reasonable price.
PostPosted: February 6th, 2016, 10:07
Already started to copy files..
My question is how to fix this issue, HDDsupertool return same error in both usb and sata board used.
Let me know the procedure to fix DIY (WDR 6, Hddsupertool)
PostPosted: February 6th, 2016, 22:06
The drive could be SED locked so you have no system area access. PC3000 is able to easily bypass this.
Also sometimes these drives will detect straight away but then become BSY and unresponsive within a couple of seconds (until slow fix applied). Try getting everything set up ready to apply and then just before you run it repower the drive then immediately start the fix.
PostPosted: February 7th, 2016, 5:27
+1 :good:
http://www.rescue-it.se
PostPosted: February 7th, 2016, 9:04
When it was USB there was no ATA return data indicating that the USB bridge did not accept any vendor specific commands. Now with SATA there is ATA return data. It is failing one of the vendor specific commands. The only way to tell where it is failing is with a modified script that has some extra echo commands in place right before each command (I believe I emailed the OP a modified script). I am curious to see if the super-on command is successful, but then it fails the command to read a module.
http://www.hddsuperclone.com
Home of HDDSuperClone
PostPosted: February 7th, 2016, 11:58
The data I have received in a reply indeed indicates that the drive is accepting the first VSC to enable special commands (super-on), but then failing to accept the next command to prepare for module access.
It accepts this:
# enable vendor specific commands
echo "Enabling vendor specific commands"
buffersize 0
setreadpio
ata28cmd 0x45 0x0b 0x00 0x44 0x57 0xa0 0x80
# check if command failed
gosub status_check
But it does not accept this:
# vsc to prepare (command to set for module 01 access)
echo "Preparing for read"
buffersize 0x200
clearbuffer
setbuffer 0
  08 00 01 00 01
endbuffer
setwritepio
ata28cmd 0xd6 0x01 0xbe 0x4f 0xc2 0xa0 0xb0
gosub status_check
I am not familiar with the SED lock, but from the quick reading I have done there is no way it can be overcome by HDDSuperTool, if that is indeed what is preventing the access.
PostPosted: February 13th, 2016, 11:07
Hello Thx to Everyone who guided me to fix slow issue and just finished 540GB of Data ~40MB/s
1. WDR 5.3 -->
Sata is connected in kernel mode and Region map edited
2. WDMarvel beta 7a -->
all modules saved using overlay and directory modules from same firmware version (6.18H) in download section
3. WDMarvel23 -->
Tried read modules using the same overlay (ID11) and Dir (ID01) from the same FW 6.18 by sectors copy 0
(not by ID) only mod 02 and mod 32 but they are overlapped with other modules. So i tried by Dir edit and
subtracted 1 in starting ABA and got correct modules 02 and 32. then applied manually slow fix using HxD and
write back to SA and Adjusted check sum using Recalc KS in Edit module
4. WDR 5.3 -->
Region Map Corrected to original Value
5. Data copied at ~40MB/s
6. Finished
Users browsing this forum: No registered users and 66 guests
