 Post subject: Unlock Samsung HD103 SI (ATA password)
PostPosted: December 21st, 2015, 18:31
i have try to unlock two HD103SI Drives.
I dont know the password, i believe a virus may set to locked mode with random password.
I have a another bunch of WD green series drives that i could unlocked with a master password (wdcwdc...).
To unlock the two Samsung drives i have read a unlock thread about a HM160HC drive:
http://forum.hddguru.com/viewtopic.php?f=1&t=28590
I did the same steps and receive this data from the 16 Security Module via SHT2:
00000000  53 45 43 55 52 49 54 59 16 00 00 00 00 00 00 00  SECURITY........
00000010  01 51 05 00 00 00 00 00 00 00 00 00 00 00 00 00  .Q..............
00000020  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000030  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000040  47 13 51 A8 D1 18 73 DB 7A B5 5B F0 A7 9F 98 80  G.Q¨Ñ.sÛzµ[𧟘€
00000050  58 10 4A 4B 00 00 00 00 00 00 00 00 00 00 00 00  X.JK............
00000060  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000070  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000080  BF 5A 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ¿Z..............
00000090  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000000A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000000B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000000C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000000D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000000E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000000F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000100  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000110  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000120  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000130  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000140  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000150  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000160  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000170  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000180  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000190  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000001A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000001B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000001C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000001D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000001E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000001F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
After reading the HM160HC thread i expect the password in offset 00000040 to 00000050.
I have tried this (and other variants e.g. 00000030 to 00000040).
Additionally to use Vicoria 4.46 b to unlock i used HDAT2 in MS-DOS.
The assumed password seems to be wrong (see attachment).
As a final step i read the 16 Security Module from a unlocked (never locked) Samsung HD154UI and i receive this:
00000010  00 51 01 00 00 00 00 00 00 00 00 00 00 00 00 00  .Q..............
00000040  8C 38 29 05 96 D1 91 F9 50 06 CC 8C 32 C7 59 39  Œ8).–Ñ‘ùP.ÌŒ2ÇY9
00000050  83 63 B7 02 00 00 00 00 00 00 00 00 00 00 00 00  ƒc·.............
00000080  87 CA 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ‡Ê..............
Nearly the same data pattern, i hoped i can see a bigger difference betwenn a locked drive and a an unlocked drive to figure out, where the password is.
Can anybody help me to locate the the password?
 Post subject: Re: Unlock Samsung HD103 SI (ATA password)
PostPosted: December 22nd, 2015, 20:07
Password is encrypted. You need just write 0 to 0x10 and write module back to drive. That is it.
PostPosted: December 22nd, 2015, 21:08
Witch tool can write modules to the drive?
The version of SHT2 that i am using, is only a free version and allow read only.
PostPosted: December 23rd, 2015, 11:50
what drives the version of f/w? have you tried zu ?
PostPosted: February 29th, 2016, 22:16
I had tryed ZU in December 2015 on a Core I 5 System.
It cant unlocked the Disk, instead it run endless without a influence.
Now i tryed on an another System and it unlocks the Disk in milliseconds.
