 Post subject: beeping WD5000BMVV
PostPosted: April 6th, 2016, 10:26
Trying to recover data from a WD5000BMVV with no luck. It'll never actually mount properly on the computer. In ubuntu, it shows in disk utility but nothing can be done with it. In other applications, it never shows up.
When it first spins up it beeps 3-4 times. Seems to me like a PCB issue.
So I'd like to get your opinion at this point. I'm familiar with data recovery on a software level but replacing PCBs is uncharted territory.
Looks like I can either solder onto the current PCB to try to hook up to SATA connections or I can buy the PCB 2060-771817-001
What's involved with replacing the PCB?
 Post subject: Re: beeping WD5000BMVV
PostPosted: April 6th, 2016, 10:33
can you record the sound and upload here ?
if drive spins up and beeps, it can be heads/media damage and changing pcb will not help. In fact pcb fault on these WD drive is very very rare.
Data Recovery Pakistan
PostPosted: April 6th, 2016, 10:46
"beeping" sounds from a WD5000BMVV its 99,9% not related to PCB.
If data has value, stop connecting the drive and seek pro assistance.
at every "beep" there is a risk that a part of or all your data get destroyed.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: April 8th, 2016, 2:14
Agree with others, not a PCB issue. It's heads/media.
PostPosted: April 8th, 2016, 2:58
May be headstuck problem my be other problem.
Expect, the Unexpected
PostPosted: April 13th, 2016, 11:07
https://www.youtube.com/watch?v=dhmjxtEHJi0
PostPosted: April 13th, 2016, 11:13
Bye bye data
PostPosted: April 13th, 2016, 11:24
Sounds bad. Likely media has been scratched, therefore data might not be accessible.
PostPosted: April 13th, 2016, 23:39
Damn. So no PCB then, eh?
PostPosted: April 14th, 2016, 2:54
+1
not a pcb issue.
If data is important contact a DR Company for further diagnosis.
PostPosted: April 14th, 2016, 4:09
One or two head crashed, head stack assembly cant park, head arm(s) without slider and head, sliding on surface causing critical media damage.
Users browsing this forum: No registered users and 153 guests
