 Post subject: WD5003AZEX
PostPosted: March 30th, 2016, 15:57
Had my WD Caviar Black 500GB drive die on me. Initially the drive wouldn't even power on so I swapped out the main board, now I have power and disk is spinning up but weird clicking noise. I opened it up and took this video. Anyone have any ideas on whats going on with this?
https://youtu.be/8N52UBhV4Z4
Please let me know. Thanks!
 Post subject: Re: WD5003AZEX
PostPosted: March 30th, 2016, 16:37
Yes, likely the PCB is not compatible as is due to unique adaptives.
As far as opening the drive and running the without cover: good luck.
PostPosted: March 31st, 2016, 1:32
agreed,
this is very often that people first mess up and than ask on forums.
Opening the hard drive in non-clean environment is really a bad idea what is more you have power it up.
you should send it to a DR company to check if there is some hope left for it.
good luck
Data Recovery Pakistan
PostPosted: March 31st, 2016, 1:36
Yep, you just turned a simple recovery to a more complex one. :(
Users browsing this forum: No registered users and 213 guests
