 Post subject: New Seagate ST1000DM003, is that noise normal?
PostPosted: June 5th, 2016, 12:20
I have bought ST1000DM003, and this drive is making disturbing sounds.
Is that normal?
Record:
https://www.youtube.com/watch?v=mZcfUaIJaXo
 Post subject: Re: New Seagate ST1000DM003, is that noise normal?
PostPosted: June 6th, 2016, 1:52
No, it isn't.
Backup immediately.
Then, post here raw SMART using CrystalDisk or similar software. But it's pretty obvious there is degraded media there.
PostPosted: June 6th, 2016, 8:22
Heres SMART and MHDD
PostPosted: June 6th, 2016, 9:01
@edit
Its new hdd with only windows installed
PostPosted: June 6th, 2016, 16:25
What do the SMART data look like now, after the 1TB surface scan?
The Raw Read Error Rate and Hardware ECC Recovered attributes look bad. The ideal normalised value for the RRER should be 120. The Seek Error Rate data are not yet statistically significant (the drive hasn't yet executed 1 million seeks).
PostPosted: June 6th, 2016, 16:45
No, that is normal for seagate hard drives. SMART not showing this properly. (u can check other seagate smart on google images)
After surface scan still looks same
PostPosted: June 6th, 2016, 17:10
A value of 75 for the RRER is not normal for your drive, unless Seagate has changed something.
Seagate's Seek Error Rate, Raw Read Error Rate, and Hardware ECC Recovered SMART attributes:
http://www.users.on.net/~fzabkar/HDD/Se ... R_HEC.html
PostPosted: June 6th, 2016, 19:25
Oh, okay I dont know about that, I will change this hdd for WD10EZEX
PostPosted: June 6th, 2016, 20:14
Show us the SMART data now. Your surface scan was very good, so maybe the numbers will be much better after the scan.
Users browsing this forum: No registered users and 90 guests
